iphone and the dude
juste for fun ( and work of course ) theDude work on iphone
Nice !
Thank you for sharing.
What version of the dude are you using. It looks way different from mine.
i think its the webinterface
yes this is the web interface opened trought iPhone Safari Browser.
I use iPhone from September, and the view of the web interface is cool :slight_smile: thanks to all developers :wink:
Hi I havent had my iPhone that long and was wondering how I get the dude on to it, as it would be realy handy for monotoring my network out and about
P.s. My iphone is completeley unblocked
Jake :smiley:
You should be able to access The Dude by it’s IP address through your web browser, if the IP is a public one.
Hi svasseur
I have setup Dude Server on Win 2003 and works just fine. I have installed I Dude in iphone and i wanted to monitor my network on iphone. My server in local but i have port forwad on the public ip address to local ip addres which is win 2003 ip .
But on the iphone tell me to type XML URL and password.
XML URL means public ip address and password means dude password.
If you can help on this.
thx
Selim
hi …
Yes i’m looking to know how i can config the iphone dude ???
any one can tell us plz ?
All they are doing is pulling up the web page of the dude.
Connect your phone to your company wifi and then browse to the server…
ok i mean when dude built to be compatibility for Apple Iphone that mean theres must be Clarify and explain how to correct installation
anyway i got it from “App Store” in my Iphone
then it’s installed
BUT …
:open_mouth: HOW I CAN CONFIG IT TO MY IPHONE :open_mouth: PLZ
We didn’t make this program, I have never heard about it.
Well, nice words
So this site for technical support and exchange of experiences and ideas must be put on each of the poses the idea illustrated
And if the idea is supposed to complete the team based on this site that have a role either in the application of the idea that illustrated or revoke participation in order not to take time and effort members
yes
thank you :slight_smile:
I stand corrected… that looks like a real app. I don’t have an iphone to test with.
I will check it out as soon as I can borrow a phone :slight_smile:
The app some basic description of its functions, I installed it on a co-workers phone. After seeing the instructions and the low rating I decided to uninstall it.
I found the app listed as it should be at the iphone store.
http://itunes.apple.com/us/app/i-dude/id368416112?mt=8
Description
This application allows you to connect to different servers Mikrotik Dude to keep eyes on your network.
The Dude network monitor is a great new application by MikroTik which can successfully improve the way you manage your network environment. With iDude, you can automatically discover the network to monitor the status of your services and server. You can now connect you from anywhere on the application Dude. And then view the different states of servers and services and directly consult the MAP of your network.
You also have the ability to easily add a xml file hosted on your server, add test sites accessible directly from your iPhone.
Note the use of this application requires php to put on the server that hosts Dude. Please don’t hesitate to contact us for more information.
To configure the tests links, information pages or connection information for Dude. You need to set up the XML file in format “Apple plist” on your server.
I didn’t want to add php to my server or change the XML format…
The support page http://www.axianet.ch/iphone_idude.htm
Ok sir
my mikrotik rauter ip is 10.0.0.139 and user is:123 the password:123
just tell my step by step as we need like any program
or I’m going to be stubed :slight_smile: … If you acttch some pics that will be more nice from you
thank you
we didn’t make this program, and we don’t know how to use it. please contact the developer for help.
I finally released the 2.0 version of iDude.
It’s a Full update of the program, a lot of new feature :
  • Direct connection to the Web service of Mikrotik Dude, no more need PHP script.
  • Easy to add and delete Dude connections directly from the application
  • Added icons and images in HD for iPhone 4 with Retina display
  • Added a adapted version for the iPad
  • Added multi-tasking, now the application stay open
  • Now it is possible to display several maps network automatically according to the config of Mikrotik Dude.
The update is free for all user of the iDude 1.0 !
Don’t hesitate to contact me for any question or remark.
The app store link : http://itunes.apple.com/app/i-dude/id368416112?mt=8
