Someone have one step by step config to make possible connect to VPN using iPhone ?
Can be L2TP or IKE or IPSEC. Any guide that really Works.
I appreciate any help.
thanks
thanks
in QuickSet, click the “VPN” checkbox, and a L2TP+IPsec setup will be made automatically, and you can connect right away. So just one click in QuickSet page.
This is really nice! Will this also add necessary firewall rules?
Yes, it does
You can check the step by step guide of How to setup VPN on Iphone in this Cheap VPN’s post: https://www.bestvpnprovider.com/buy-cheap-vpn/.
Yes, if you need more settings, you can create the same by hand
Sent from my iPhone using Tapatalk
I tried to edit the previous post with no luck.
Forwarding ports 500 and 4500 UPD to mikrotik worked!
Thanks for the tip of configuring vpn in quickset! TOP
Enviado do meu iPad usando o Tapatalk Pro
