IPIP Routing broken after 7.1 upgrade
I have had an IPIP Tunnel with IPSec encryption to a remote location active for more then a year now. This worked perfectly fine until I upgraded my side to RouterOS 7.1 yesterday.
The Tunnel is still active, but the routing is broken which was working fine before.
I can now only ping the remote side when explicitly selecting the IPIP Tunnel interface as “ping interface”. When I try to ping the same IP from my LAN bridge it will give me timeouts.
Does anyone know what change in RouterOS 7.1 might have caused this?
Below I have printed the Interface, IP Addresses and IP Routes.
I also noticed that all the Route Nexthops are marked unreachable in Winbox (see attachment).
If anyone can get me up and running again that would be great.
interface/ipip/print
Flags: R - RUNNING
Columns: NAME, MTU, ACTUAL-MTU, LOCAL-ADDRESS, REMOTE-ADDRESS, KEEPALIVE, DSCP
#   NAME               MTU   ACTUAL-MTU  LOCAL-ADDRESS  REMOTE-ADDRESS      KEEPALIVE  DSCP
0 R ipip-tunnel-joure  auto        1390  0.0.0.0        remote.domain.name  10s,10     inherit
ip/address/print
Flags: D - DYNAMIC
Columns: ADDRESS, NETWORK, INTERFACE
#   ADDRESS           NETWORK         INTERFACE
0   10.2.0.1/24       10.2.0.0        bridge-lan
1   10.2.1.1/24       10.2.1.0        bridge-iptv
2   172.16.0.2/30     172.16.0.0      ipip-tunnel-joure
3 D 10.182.16.93/22   10.182.16.0     vlan4-iptv
4 D 84.80.230.176/32  195.190.228.97  pppoe-kpn
ip/route/print
Flags: D - DYNAMIC; A - ACTIVE; c, s, d, v, y - COPY
Columns: DST-ADDRESS, GATEWAY, DISTANCE
#     DST-ADDRESS        GATEWAY            DISTANCE
  DAv 0.0.0.0/0          pppoe-kpn                 1
0  As 10.1.0.0/24        172.16.0.1                1
  DAc 10.2.0.0/24        bridge-lan                0
  DAc 10.2.1.0/24        bridge-iptv               0
  DAc 10.182.16.0/22     vlan4-iptv                0
  DAc 172.16.0.0/30      ipip-tunnel-joure         0
  DAc 195.190.228.97/32  pppoe-kpn                 0
  DAd 213.75.112.0/21    10.182.16.1              10
