IPIP tunnel + IPv6
I have IPIP tunnel setup between two routers and with IPv4 it works flawlessly, but now I would like to “share” my public IPv6 space from router1 to router2, so I thought that if I simply add a private IPv6 address on each router and then route a subset of my IPv6 range through that, but I can’t get it to even ping the private IPv6 addresses from one router to another.
Have I missed anything or is this not the way to go?
Thanks for any insights!
Re, Uros
just to post my solution, I established a GRE tunnel over the IPIP tunnel already established and on the new GRE tunnel I have set the IPv6 settings and it works like a charm.
Thank you MT!
Re, Uros
