Hello to all
I have a some server inside my network, listening on port 8800 and 443 and … , and i would like to be able to accept incoming connections from all wan than mean wan1 and wan2 and wan 3 and wan 4 . and i use the below codes .
Now everything work fine except IPIP tunnels , i have also 44 Tunnel but only the active wan Tunnel will be up that mean wan 1 Tunnels will be up and when disable wan1 , wan2 will be active and Tunnels wan2 will be up and when disable wan 2 , wan 3 will be active and tunnel wan 3 will be up and … .
So whats the problem and how can i fix this problem ? i want all my tunnel will be active without disabling wans .
# redirect incoming traffic in wan1 and wan2 and wan 3 and wan 4 to the local servers
/ip firewall nat add chain=dstnat protocol=tcp dst-port=8800 in-interface=wan1 action=dst-nat to-addresses=192.168.0.1 to-ports=80
/ip firewall nat add chain=dstnat protocol=tcp dst-port=22 in-interface=wan2 action=dst-nat to-addresses=192.168.0.12 to-ports=22
/ip firewall nat add chain=dstnat protocol=tcp dst-port=5060 in-interface=wan3 action=dst-nat to-addresses=192.168.0.14 to-ports=5060
# what comes from wan1, gets out from wan1
/ip firewall mangle add action=mark-connection chain=input in-interface=PPPOE-ISP1 new-connection-mark=wan1_conn passthrough=yes disabled=no comment="in wan1,out wan1"
/ip firewall mangle add action=mark-routing chain=output connection-mark=wan1_conn new-routing-mark=wan1_traffic passthrough=no disabled=no comment="in wan1,out wan1"
# what comes from wan2, gets out from wan2
/ip firewall mangle add action=mark-connection chain=input in-interface=PPPOE-ISP2 new-connection-mark=wan2_conn passthrough=yes disabled=no comment="in wan2,out wan2"
/ip firewall mangle add action=mark-routing chain=output connection-mark=wan2_conn new-routing-mark=wan2_traffic passthrough=no disabled=no comment="in wan2,out wan2"
# what comes from wan3, gets out from wan3
/ip firewall mangle add action=mark-connection chain=input in-interface=PPPOE-ISP3 new-connection-mark=wan3_conn passthrough=yes disabled=no comment="in wan3,out wan3"
/ip firewall mangle add action=mark-routing chain=output connection-mark=wan3_conn new-routing-mark=wan3_traffic passthrough=no disabled=no comment="in wan3,out wan3"
# what comes from wan4, gets out from wan4
/ip firewall mangle add action=mark-connection chain=input in-interface=PPPOE-ISP4 new-connection-mark=wan4_conn passthrough=yes disabled=no comment="in wan4,out wan4"
/ip firewall mangle add action=mark-routing chain=output connection-mark=wan4_conn new-routing-mark=wan4_traffic passthrough=no disabled=no comment="in wan4,out wan4"
# port forwards from wan1, gets out from wan1
/ip firewall mangle add action=mark-connection chain=forward in-interface=PPPOE-ISP1 connection-state=new new-connection-mark=wan1_pfw passthrough=no disabled=no comment="pfw wan1, out wan1"
/ip firewall mangle add action=mark-routing chain=prerouting in-interface=ETH1-LAN connection-mark=wan1_pfw new-routing-mark=wan1_traffic passthrough=no disabled=no comment="pfw wan1, out wan1"
# port forwards from wan2, gets out from wan2
/ip firewall mangle add action=mark-connection chain=forward in-interface=PPPOE-ISP2 connection-state=new new-connection-mark=wan2_pfw passthrough=no disabled=no comment="pfw wan2, out wan2"
/ip firewall mangle add action=mark-routing chain=prerouting in-interface=ETH1-LAN connection-mark=wan2_pfw new-routing-mark=wan2_traffic passthrough=no disabled=no comment="pfw wan2, out wan2"
# port forwards from wan3, gets out from wan3
/ip firewall mangle add action=mark-connection chain=forward in-interface=PPPOE-ISP3 connection-state=new new-connection-mark=wan3_pfw passthrough=no disabled=no comment="pfw wan3, out wan3"
/ip firewall mangle add action=mark-routing chain=prerouting in-interface=ETH1-LAN connection-mark=wan3_pfw new-routing-mark=wan3_traffic passthrough=no disabled=no comment="pfw wan3, out wan3"
# port forwards from wan4, gets out from wan4
/ip firewall mangle add action=mark-connection chain=forward in-interface=PPPOE-ISP4 connection-state=new new-connection-mark=wan4_pfw passthrough=no disabled=no comment="pfw wan4, out wan4"
/ip firewall mangle add action=mark-routing chain=prerouting in-interface=ETH1-LAN connection-mark=wan4_pfw new-routing-mark=wan4_traffic passthrough=no disabled=no comment="pfw wan4, out wan4"
# routing rules for wan1_traffic and wan2_traffic and wan3_traffic and wan4_traffic
/ip route add dst-address=0.0.0.0/0 gateway=PPPOE-ISP1 distance=1 routing-mark=wan1_traffic disabled=no
/ip route add dst-address=0.0.0.0/0 gateway=PPPOE-ISP2 distance=1 routing-mark=wan2_traffic disabled=no
/ip route add dst-address=0.0.0.0/0 gateway=PPPOE-ISP3 distance=1 routing-mark=wan3_traffic disabled=no
/ip route add dst-address=0.0.0.0/0 gateway=PPPOE-ISP4 distance=1 routing-mark=wan4_traffic disabled=no
/ip route add dst-address=0.0.0.0/0 gateway=PPPOE-ISP1 distance=1 check-gateway=ping disabled=no
/ip route add dst-address=0.0.0.0/0 gateway=PPPOE-ISP2 distance=2 check-gateway=ping disabled=no
/ip route add dst-address=0.0.0.0/0 gateway=PPPOE-ISP3 distance=3 check-gateway=ping disabled=no
/ip route add dst-address=0.0.0.0/0 gateway=PPPOE-ISP4 distance=4 check-gateway=ping disabled=no
