we currently have several sites which connect back to our main site using IPIP tunnel w/ IPSEC. All are on statics and work fine.
What’s the best method for 4 other sites that have dynamically assigned public IPs to connect back into the main office?
mrz
July 19, 2010, 6:23am
2
It is possible without IPIP tunnels.
On your main router set ipsec peer as 0.0.0.0/0 and generate-policy=yes.
Now other peers with dynamic addresses will be able to connect.
Thanks for the response, what about the remote site side?
mrz
July 19, 2010, 8:53am
4
both sides can’t be dynamic at the same time. Then you need to set up dynamicdns and run a script which checks dns for address changes and updates configuration accordingly.
Sorry I didnt explain very well..
The main site is a static IP, So all I do is set the peer address like below:
address=0.0.0.0/0:500 auth-method=pre-shared-key secret="test"
generate-policy=yes exchange-mode=main send-initial-contact=no
nat-traversal=no proposal-check=obey hash-algorithm=md5
enc-algorithm=3des dh-group=modp1024 lifetime=1d8h lifebytes=0
This automatically generates the IPSEC policy yes?
On the remote side do I set the peer address as our public and also generae policy? If not how do i set the policy on the remote side?
mrz
July 21, 2010, 6:33am
6
On remote site you set the peer address and add policy manually. Because it is not possible to generate policy from nothing (if one peer has generate-policy enabled then other peer must have manually added policy).
This is my config at the moment which I believe should work? But Doesnt.
Remote Site:
Flags: X - disabled, D - dynamic, I - inactive
0 src-address=192.168.20.0/24:any dst-address=192.168.5.0/24:any
protocol=all action=encrypt level=require ipsec-protocols=esp tunnel=yes
sa-src-address=0.0.0.0 sa-dst-address=MAINSITEPUBLICIP proposal=default
priority=0
Flags: X - disabled
0 address=MAIMSITEPUBLICIP/32:500 auth-method=pre-shared-key secret="test"
generate-policy=yes exchange-mode=main send-initial-contact=yes
enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=0
dpd-interval=disable-dpd dpd-maximum-failures=1
Main Site:
What’s worng?
mrz
July 22, 2010, 6:12am
8
you need to specify sa-src-address. As address is dynamic you can use script to detect address changes and update sa-src-address parameter.
Sorry to ask! Do you have one?
mrz
July 22, 2010, 8:53am
10
script is quite simple. Add comment to policy for example “myPolicy” to find it in script and lets say public interface is ether1
:local publicIP [/ip address get [find interface=ether1] address];
#strip off netmask
:for i from=( [:len $publicIP] - 1) to=0 do={
:if ( [:pick $publicIP $i] = "/") do={
:set publicIP [:pick $publicIP 0 $i];
#get sa-src
:local saSrc [/ip ipsec policy get [find comment="myPolicy"] sa-src-address];
:if ($saSrc != $publicIP) do={
/ip ipsec policy set [find comment="myPolicy"] sa-src-address=$publicIP
Add it to scheduler and run say once in a minute.
Caci99
October 14, 2010, 8:31pm
11
I think your post needs a little correction. Your script is ok when the dynamic IP is on the local router.
The problem exist on the remote router too, when you have to set:
/ip ipsec policy
… sa-dst-address=“dynamic_IP”…
Also, there is a mistake in the script. I can not find “Comment” for the /ip ipsec policy. I mean there is no
way you can assign Comment. I am testing it on RB411 ROS 3.30
So I writed down another script:
:global “Remote_1” [:resolve “Remote.changeip.org ”]
:global saDst [/ip ipsec policy get 0 sa-dst-address]
:if ($saDst != $“Remote_1”) do={
/ip ipsec policy set [find sa-dst-address=$saDst] sa-dst-address=$“Remote_1”}
Where Remote.changeip.org is the dns name of the remote router on the internet
Do you think this is okay?
Possible you find a working configuration here: http://gregsowell.com/?p=1523
This works flawless for me.
