I have next configuration and scenario:
MIkrotik 1 ------------------------- MIkrotik2
ETH1: 10.10.10.10 ETH1: 20.20.20.20
ETH2: 192.168.70.1 ETH2: 192.168.7.105
PC1: 192.168.70.5 PC1: 192.168.7.5
MIkrotik 1
interface ipip add name=Tunnel-1 local-address=10.10.10.10 remote-address=20.20.20.20 disabled=no
ip address add address=10.0.0.1/24 interface=Tunnel-1
ip route add dst-address=192.168.7.0/24 gateway=10.0.0.2
Mikrotik 2
interface ipip add name=Tunnel-2 local-address=20.20.20.20 remote-address=10.10.10.10 disabled=no
ip address add address=10.0.0.2/24 interface=Tunnel-2
ip route add dst-address=192.168.70.0/24 gateway=10.0.0.1
I can ping from mikrotik1 mikrotik2 ist work ok.
I can not ping from PC1 to PC2
Please help me
Peter
johankosice:
MIkrotik 1
Mikrotik 2
Please help me
Peter
Peter,
Do you have proxy-arp turned on, on those interfaces facing the client pc’s?
Matt
Hi MAtt
I have not turned on proxy-arp on interface eth2. I just try turned on but canot ping pc 1 to pc2.
Hi Matt
When i try ping rrom pc1 to pc2 with pacet size 1500 ping it!!!
Where is the problem?
Peter
fatonk
April 16, 2007, 6:43am
4
What about from PC1 to ETH2: 192.168.7.105
Regards.
Faton
HI
I now try send ping from p1 to pc2 but pacet size 1500 its work ok. But only pecet size bigest 1500.
Peter
mrz
April 16, 2007, 7:13am
6
As i understood, you are trying to send packets bigger than 1500 bytes. You won’t be able to do that.
Why i dont sending small packet as 1500 bites.
Peter
fatonk
April 16, 2007, 7:38am
8
The maximum packet size in IPIP Tunnel is 1480 bytes, 20 bytes are overhead, the packet size larger than 1480 bytes will be fragmented.
Regards.
Faton
Hi
I want problem with small packet. When i ping standart packet size 32 bites ping is time out. Only when I ping with packet 1500 ping is response.
Peter
