Hi everyone,
I’m setting up my hAp ax3 with my new fiber connection, and my isp is only providing an IPv6 address through PPPoE, so I have to pass through DS-Lite for my IPv4 traffic.
I’m new to mikrotik and I don’t really know how to setup the ipipv6 tunnel with the right parameters.
I can currently ping IPv6 addresses without issues.
Here is my current configuration :
# 2024-05-04 20:41:52 by RouterOS 7.14.3
# software id = 0JBE-EMF2
# model = C53UiG+5HPaxD2HPaxD
add admin-mac=XXXXXXXXXXXXXXXXXXX auto-mac=no comment=defconf name=bridge \
port-cost-mode=short
/interface wifi
set [ find default-name=wifi1 ] channel.band=5ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40/80mhz configuration.country=Germany .mode=ap \
.ssid=MikroTik-5GHz disabled=no security.authentication-types=\
wpa2-psk,wpa3-psk
set [ find default-name=wifi2 ] channel.band=2ghz-ax .skip-dfs-channels=\
10min-cac .width=20/40mhz configuration.country=Germany .mode=ap .ssid=\
MikroTik-4E6059 disabled=no security.authentication-types=\
wpa2-psk,wpa3-psk
/interface ipipv6
add local-address=:: name=ipipv6-tunnel1 remote-address=""
/interface vlan
add interface=ether1 name=vlan7 vlan-id=7
/interface pppoe-client
add add-default-route=yes disabled=no interface=vlan7 name=pppoe-out1 \
use-peer-dns=yes user=XXXXXXXXXXXXXXXXXXXXX
add comment=defconf name=WAN
add comment=defconf name=LAN
add address-pool=default-dhcp interface=bridge lease-time=10m name=defconf
add bridge=bridge comment=defconf interface=ether2 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether3 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether4 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=ether5 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi1 internal-path-cost=10 \
path-cost=10
add bridge=bridge comment=defconf interface=wifi2 internal-path-cost=10 \
path-cost=10
set udp-timeout=10s
add comment=defconf interface=pppoe-out1 list=WAN
192.168.88.0
/ip dhcp-client
192.168.88.1
set allow-remote-requests=yes
/ip dns static
established,related,untracked
invalid
in-interface-list=!LAN
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
connection-state=invalid
add action=masquerade chain=srcnat comment="defconf: masquerade" disabled=yes \
ipsec-policy=out,none out-interface=*D
/ipv6 route
add disabled=yes distance=1 dst-address=fe80::/64 gateway=pppoe-out1 \
routing-table=main scope=30 suppress-hw-offload=no target-scope=10
/ipv6 address
add address=::1 from-pool=pool-pd interface=bridge
/ipv6 dhcp-client
add interface=pppoe-out1 pool-name=pool-pd request=prefix
/ipv6 firewall address-list
/ipv6 firewall filter
invalid
icmpv6
add action=accept chain=input comment="defconf: accept UDP traceroute" port=\
33434-33534 protocol=udp
udp src-address=fe80::/10
protocol=udp
ipsec-ah
ipsec-esp
!LAN
icmpv6
500,4500 protocol=udp
ipsec-ah
ipsec-esp
!LAN
/ipv6 firewall nat
add action=masquerade chain=srcnat out-interface=pppoe-out1 \
out-interface-list=WAN
/system note
set show-at-login=no
/tool mac-server
/tool mac-server mac-winbox
