IPsec+3g+Dyndns help.
Could you please help me to configure mikrotik
I'm trying to pick between two IPsec routers. WAN via 3G modems. Accordingly, use dynamic IP. To automatically update the configuration are using DynDNS. Configuration have listed below.
3G interent works but tunnel does not rise.
siteA
/system script
add name=dynamic-dns-script policy=
ftp,reboot,read,write,policy,test,winbox,password,sniff,sensitive source="\
User account info of DNSoMatic\r\
\n:global maticuser "ххххх"\r
\n:global maticpass "ххххх"\r
\n:global matichost "testtele2sitea.dyndns.org"\r
\n# No more changes need\r
\n\r
\n:global previousIP\r
\n\r
\n# Print values for debug\r
\n:log info "DNSoMatic: Updating dynamic IP on DNS for host $matichost"
\r
\n:log info "DNSoMatic: User $maticuser y Pass $maticpass"\r
\n:log info "DNSoMatic: Last IP $previousIP"\r
\n\r
\n# get the current IP address from the internet (in case of double-nat)\r
\n/tool fetch mode=http address="checkip.dyndns.org" src-path="/" dst-
path="/dyndns.checkip.html"\r
\n:local result [/file get dyndns.checkip.html contents]\r
\n\r
\n# parse the current IP result\r
\n:local resultLen [:len $result]\r
\n:local startLoc [:find $result ": " -1]\r
\n:set startLoc ($startLoc + 2)\r
\n:local endLoc [:find $result "" -1]\r
\n:global currentIP [:pick $result $startLoc $endLoc]\r
\n:log info "DNSoMatic: IP actual $currentIP"\r
\n\r
\n# Touching the string passed to fetch command on "src-path" option\r
\n:local str "/nic/update?hostname=$matichost&myip=$currentIP&wildcard
=NOCHG&mx=NOCHG&backmx=NOCHG"\r
\n\r
\n:if ($currentIP != $previousIP) do={\r
\n:log info "DNSoMatic: Update need"\r
\n:set previousIP $currentIP\r
\n:log info "DNSoMatic: Sending update $currentIP"\r
\n:log info [ :put [/tool fetch host=MT user=$maticuser password=$maticp
ass mode=http address="updates.dnsomatic.com" src-path=$str dst-path=$
matichost]]\r
\n:log info "DNSoMatic: Host $matichost updated on DNSoMatic with IP $c
urrentIP"\r
\n} else={\r
\n:log info "DNSoMatic: Previous IP $previousIP and current $currentIP
equal, no update need"\r
\n}"
/system scheduler
add comment="" disabled=no interval=10m name=dynamic-dns-schedule on-event=dynamic-dns-script
start-date=jan/01/1970 start-time=00:00:01
add action=accept chain=srcnat comment="NAT bypass" disabled=no dst-address=
192.168.0.0/16 out-interface=ppp-out1
add action=masquerade chain=srcnat comment="default PAT" disabled=no out-interface=
ppp-out1
/ip ipsec peer
add address=1.1.1.1/32 port=500 auth-method=pre-shared-key dh-group=modp1024
disabled=no dpd-interval=disable-dpd dpd-maximum-failures=1
enc-algorithm=3des exchange-mode=main generate-policy=no hash-algorithm=
md5 lifebytes=0 lifetime=1d nat-traversal=no proposal-check=obey secret=
test send-initial-contact=yes
/ip ipsec policy
add action=encrypt disabled=no dst-address=192.168.88.0/24 dst-port=any
ipsec-protocols=esp level=require priority=0 proposal=default protocol=
all sa-dst-address=2.2.2.2 sa-src-address=1.1.1.1 src-address=
192.168.87.0/24 src-port=any tunnel=yes
/system script
add name=dynamic-router-update policy=
:global LocalSite [:resolve testtele2sitea.dyndns.org]\r
\n:global RemoteSite [:resolve testtele2siteb.dyndns.org]\r
\n/ip ipsec policy set 0 sa-dst-address=$RemoteSite sa-src-address=$Loca
lSite\r
\n/ip ipsec peer set 0 address="$RemoteSite/32:500""
