I was trying to find why I had poor performance over my VPN provider until I found that Fasttrack was causing the issue. I then implemented this solution https://blog.johannfenech.com/mikrotik-fasttrack-configuration-with-l2tp-ipsec-vpn/ which solved my issue.
My question is more about the two other default rule in my hAP ac lite which I thought would do basically the same.. defconf accept in ipsec policy and defconf accept out ipsec policy by accepting all ipsec traffic prior to the fasttrak policy. I then noticed the accept in ipsec policy counter do increase but no the out. Could someone explain the purpose of those policy?
Rock.
