IPsec behind transparent(?) NAT
I’m trying to make an encrypted IPsec-only tunnel between two points. But I don’t know the correct settings for this.
I have:
Point-1 which have public IP-address accessible from internet.
Point-2 which have IP-address that is not accessible from internet - it is behind ISP NAT.
We asked ISP for a public IP, and they gave us a separate NAT router address which have unique public address and configured to translate incoming traffic from the internet to the Point-2 local IP.
What config we have for now:
We generated certificates for both sides.
We create “input” firewall rules to accept IPsec-esp and UDP ports 500 and 4500 on both sides.
Made proposals same for two points:
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-128-cbc
Made policies on both sides:
Point-1
/ip ipsec policy
add dst-address=70.70.70.70/32 sa-dst-address=70.70.70.70 sa-src-address=80.80.80.80 src-address=80.80.80.80/32 tunnel=yes
Point-2
/ip ipsec policy
add dst-address=80.80.80.80/32 sa-dst-address=80.80.80.80 sa-src-address=70.70.70.70 src-address=70.70.70.70/32 tunnel=yes
Made peers on both sides:
Point-1
/ip ipsec peer
add address=70.70.70.70/32 auth-method=rsa-signature certificate=Point1-cert dh-group=modp1024 disabled=yes enc-algorithm=aes-128 hash-algorithm=sha256 remote-certificate=Point2-cert send-initial-contact=no
Point-2
/ip ipsec peer
add address=80.80.80.80/32 auth-method=rsa-signature certificate=Point2-cert dh-group=modp1024 disabled=yes enc-algorithm=aes-128 hash-algorithm=sha256 remote-certificate=Point1-cert
And the result is:
PH2 phase stuck at msg1 sent and after some time peer reconnecting.
Is this even possible to connect these two?
Any help?
You should use your local addresses on the RB1100 not the public address outside the NAT.
I tried to put local address to SA Src.Address on RB1100. It’s now established, but I can’t access the other end - ping timeout.
Instead make a GRE tunnel with IPsec protection (configure using the easy IPsec config in the tunnel interface), add a local network address to each of the tunnel endpoints
(e.g. 10.0.0.1/30 and 10.0.0.2/30) and route your traffic over that tunnel using static routes, OSPF or BGP.
