IPsec between 2 RouterOS (Vs.3.10)
hi all,
I want to connect two offices using an ipsec VPN.
Following the Wiki: http://wiki.mikrotik.com/wiki/IPSec_VPN_with_Dynamic_Routing_/_Mikrotik_and_Cisco
This works fine, as long as WAN1 (10.10.1.100) and WAN2 (10.10.1.200) are in the same network:
Router 1
interface ipip \
add name="Tunnel1" mtu=1480 local-address=10.10.1.100 remote-address=10.10.1.200 comment="" disabled=no
ip address \ add address=10.10.1.100/24 network=10.10.1.0 broadcast=10.10.1.255 interface=ether1 comment="" disabled=no
ip address \ add address=192.168.1.1/24 network=192.168.1.0 broadcast=192.168.1.255 interface=ether2 comment="" disabled=no
ip address \ add address=172.16.0.1/30 network=172.16.0.0 broadcast=192.168.0.3 interface=Tunnel1 comment="" disabled=no
routing rip \ set redistribute-static=no redistribute-connected=no redistribute-ospf=no redistribute-bgp=no \
metric-static=1 metric-connected=1 metric-ospf=1 metric-bgp=1 update-timer=30s timeout-timer=3m garbage-timer=2m
routing rip interface \ add interface=Tunnel1 receive=v2 send=v2 authentication=none authentication-key="" \
in-prefix-list="" out-prefix-list=""
routing rip neighbor \ add address=172.16.0.2
routing rip network \ add network=192.168.1.0/24
routing rip network \ add network=172.16.0.0/30
ip ipsec proposal \
add name="IPSec" auth-algorithms=md5 enc-algorithms=3des lifetime=30m pfs-group=modp1024 disabled=no
ip ipsec peer \
add address=10.10.1.200/32:500 secret="geheim0815" generate-policy=no exchange-mode=main send-initial-contact=yes \
proposal-check=obey hash-algorithm=md5 enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=0 disabled=no
ip ipsec policy \
add src-address=10.10.1.100/32:any dst-address=10.10.1.200/32:any protocol=all action=encrypt level=require \
ipsec-protocols=esp tunnel=no sa-src-address=10.10.1.100 sa-dst-address=10.10.1.200 \
proposal=IPSec manual-sa=none dont-fragment=clear disabled=no
Router 2--same WAN network:
interface ipip \
add name="Tunnel1" mtu=1480 local-address=10.10.1.200 remote-address=10.10.1.100 comment="" disabled=no
ip address \ add address=10.10.1.200/24 network=10.10.1.0 broadcast=10.10.1.255 interface=ether1 comment="" disabled=no
ip address \ add address=192.168.2.1/24 network=192.168.2.0 broadcast=192.168.2.255 interface=ether4 comment="" disabled=no
ip address \ add address=172.16.0.2/30 network=172.16.0.0 broadcast=192.168.0.3 interface=Tunnel1 comment="" disabled=no
routing rip neighbor \ add address=172.16.0.1
routing rip network \ add network=192.168.2.0/24
ip ipsec proposal \
ip ipsec peer \
add address=10.10.1.100/32:500 secret="geheim0815" generate-policy=no exchange-mode=main send-initial-contact=yes \
ip ipsec policy \
add src-address=10.10.1.200/32:any dst-address=10.10.1.100/32:any protocol=all action=encrypt level=require \
ipsec-protocols=esp tunnel=no sa-src-address=10.10.1.200 sa-dst-address=10.10.1.100 \
Now, I changed 10.10.1.200 to 10.10.2.100, - both connected to the same Linux box, with ip_forward enabled. But, there’s no connection anymore:
interface ipip \
add name="Tunnel1" mtu=1480 local-address=10.10.1.100 remote-address=10.10.2.100 comment="" disabled=no
ip ipsec proposal \
ip ipsec peer \
add address=10.10.2.100/32:500 secret="geheim0815" generate-policy=no exchange-mode=main send-initial-contact=yes \
ip ipsec policy \
add src-address=10.10.1.100/32:any dst-address=10.10.2.100/32:any protocol=all action=encrypt level=require \
ipsec-protocols=esp tunnel=no sa-src-address=10.10.1.100 sa-dst-address=10.10.2.100 \
Router 2:
interface ipip \
add name="Tunnel1" mtu=1480 local-address=10.10.2.100 remote-address=10.10.1.100 comment="" disabled=no
ip address \ add address=10.10.2.100/24 network=10.10.2.0 broadcast=10.10.2.255 interface=ether1 comment="" disabled=no
ip ipsec proposal \
ip ipsec peer \
ip ipsec policy \
add src-address=10.10.2.100/32:any dst-address=10.10.1.100/32:any protocol=all action=encrypt level=require \
ipsec-protocols=esp tunnel=no sa-src-address=10.10.2.100 sa-dst-address=10.10.1.100 \
Please help me find the error.
How can I activate/view the IPsec log?
thanks, Stefan
