Have been able to successfully create an IPsec tunnel between a Mikrotik CCR1009 running v7.6 and a Sonicwall NSV270 running SonicOS7. The only odd issue still happening is a daily timeout of the IPsec tunnel. If you go under Active Peers it shows the tunnel connected but numeric values are not changing, traditional network test of ping, traceroute, ssh show failed response. On Sonicwall Side it show IPsec tunnel dropped but no errors reported. Other IPsec tunnels seem to be stable but those are all Mikrotik to Mikrotik connections.
To correct issue, I go back into “Active Peers” and highlight the peer and kill the connection it starts a reconnect and everything works again. Next day tunnel is in timeout state.
Tried messing with IPsec Profile > DPD but anything other than “disable DPD” and tunnel won’t connect. Proposal check is set to “obey” with Lifetime set to 1d 00:00:00
Under IPsec Proposal > Lifetime is set to 00:30:00
Any Ideas?
