IPSec between MT and WinXP
I need create L2TP/IPSec tunel between WinXP and MT. I have functionally L2TP server on MT. I need IPSec on MT.
Please help me with configuring IPSec on MT with pre-shared password on WinXP client.
I don’t want disable IPSec. I need it.
Thank’s
Add the preshared key to /ip ipsec peer section and set ‘generate-policy=yes’ for this record. There is no additional configuration needed.
Eugene
In log I found this message:
“received ISAKMP packet from x.x.x.x, phase 1, Identity protection”
“peer not configured”
Whats is wrong?
Thanks.
No proper ‘/ip ipsec peer’ section.
Eugene
In particular make sure that you have
address=0.0.0.0/0:500
and not
address=0.0.0.0/32:500
in your peer definition.
Also make sure that you have exchange-mode=main and, of course, generate-policy=yes as has been mentioned before.
