Hello!
Please help me to set up IPsec connection between 2 MT devices or MT (client) and Strongswan (server).
Server has static public IP address
Client has public dynamic address, but all connections are NATed
For example, PPPoE connection on client router gets IP address 100.64.37.102, but when it connects to main router, connection comes from 121.32.126.242
PPTP and L2TP connections is not stable, they are being filtered and shaped (client located in China), in some places they even block it. OpenVPN is completely filtered.
The only option is IPsec (IKEv2). I have Strongswan server on Ubuntu VM and it works well when I connect with Windows, iOS or Android Strongswan app
I don’t have any issues setting up IPsec between 2 MT devices with static public IPs, but with dynamic NATed address I don’t even have a clue where to begin.
I tried to connect to Strongswan server
MT client config:
/ip ipsec peer
add address=xxx.xxx.xxx.13/32 exchange-mode=ike2 generate-policy=port-strict my-id=user-fqdn:aaa@bbb.ccc.org secret=yyyyyyyyyyyyy
Strongswan config:
~$ cat /usr/local/etc/swanctl/swanctl.conf
connections {
ikev2-eap {
local {
auth = pubkey
certs = bbb.ccc.org.crt
id = bbb.ccc.org
remote {
auth = eap-radius
eap_id = %any
children {
net {
local_ts = 0.0.0.0/0
esp_proposals = aes128gcm12-aes128gcm16-aes256gcm12-aes256gcm16-modp2048-modp4096-modp1024-ecp256,aes128-aes256-sha1-sha256-modp2048-modp4096-modp1024-ecp256,aes128-sha1-ecp256,aes128-sha1-modp2048,aes128-sha1-modp1024,3des-sha1-ecp256,3des-sha1-modp1024,aes128-aes256-sha1-sha256,aes128-sha1,3des-sha1
rekey_time = 30m
dpd_action = restart
mobike = yes
fragmentation = yes
encap = yes
dpd_delay = 35s
proposals = aes256gcm16-aes256gcm12-aes128gcm16-aes128gcm12-sha256-sha1-modp2048-modp4096-modp1024-ecp256,aes256-aes128-sha256-sha1-modp2048-modp4096-modp1024-ecp256,3des-sha1-modp1024
pools=vpnguests
send_cert=always
ikev2-psk {
local {
auth = psk
id = bbb.ccc.org
remote {
auth = psk
children {
net {
rekey_time = 30m
mobike = yes
fragmentation = yes
encap = yes
dpd_delay = 35s
pools=vpnguests
version = 2
secrets {
ikev2-psk
id = aaa@bbb.ccc.org
secret = yyyyyyyy
pools {
vpnguests
addrs=10.1.0.0/16
dns=8.8.8.8
dns=4.2.2.1
Strongswan log output:
14[NET] <2057> received packet: from 121.32.126.242[23808] to xxx.xxx.xxx.13[4500] (304 bytes)
14[ENC] <2057> parsed IKE_SA_INIT request 0 [ N(NATD_D_IP) N(NATD_S_IP) No KE SA ]
14[IKE] <2057> 121.32.126.242 is initiating an IKE_SA
14[IKE] <2057> remote host is behind NAT
14[IKE] <2057> sending cert request for "CN=xxxxxxxxxxxx"
14[ENC] <2057> generating IKE_SA_INIT response 0 [ SA KE No N(NATD_S_IP) N(NATD_D_IP) CERTREQ N(MULT_AUTH) ]
14[NET] <2057> sending packet: from xxx.xxx.xxx.13[4500] to 121.32.126.242[23808] (337 bytes)
13[NET] <2057> received packet: from 121.32.126.242[23808] to xxx.xxx.xxx.13[4500] (476 bytes)
13[ENC] <2057> parsed IKE_AUTH request 1 [ IDi AUTH N(INIT_CONTACT) SA TSi TSr N(USE_TRANSP) ]
13[CFG] <2057> looking for peer configs matching xxx.xxx.xxx.13[%any]...121.32.126.242[aaa@bbb.ccc.org]
13[CFG] <ikev2-psk|2057> selected peer config 'ikev2-psk'
13[IKE] <ikev2-psk|2057> authentication of 'aaa@bbb.ccc.org' with pre-shared key successful
13[IKE] <ikev2-psk|2057> authentication of 'bbb.ccc.org' (myself) with pre-shared key
13[IKE] <ikev2-psk|2057> IKE_SA ikev2-psk[2057] established between xxx.xxx.xxx.13[bbb.ccc.org]...121.32.126.242[aaa@bbb.ccc.org]
13[IKE] <ikev2-psk|2057> scheduling rekeying in 13974s
13[IKE] <ikev2-psk|2057> maximum IKE_SA lifetime 15414s
13[IKE] <ikev2-psk|2057> expected a virtual IP request, sending FAILED_CP_REQUIRED
13[IKE] <ikev2-psk|2057> configuration payload negotiation failed, no CHILD_SA built
13[IKE] <ikev2-psk|2057> failed to establish CHILD_SA, keeping IKE_SA
13[CFG] <ikev2-psk|2057> sending RADIUS Accounting-Request to server '10.vvv.vvv.100'
13[CFG] <ikev2-psk|2057> received RADIUS Accounting-Response from server '10.vvv.vvv.100'
13[ENC] <ikev2-psk|2057> generating IKE_AUTH response 1 [ IDr AUTH N(FAIL_CP_REQ) ]
13[NET] <ikev2-psk|2057> sending packet: from xxx.xxx.xxx.13[4500] to 121.32.126.242[23808] (124 bytes)
MT client log output:
13:44:27 ipsec,info new ike2 SA (I): 100.64.37.102[4500]-xxx.xxx.xxx.13[4500] spi:8a16bb255166afb0:0d8b6e61de2bdf95
13:44:27 ipsec,info peer authorized: 100.64.37.102[4500]-xxx.xxx.xxx.13[4500] spi:8a16bb255166afb0:0d8b6e61de2bdf95
The peer is authorized, so what to do next?
When I try to connect MT to MT:
MT client config:
/ip ipsec peer
add address=xxx.xxx.xxx.21/32 auth-method=rsa-signature certificate=cert_export_ccc_ccccc.crt_0 disabled=yes exchange-mode=ike2 generate-policy=port-strict
MT server config:
/ip pool add name=rw-pool ranges=192.168.77.2-192.168.77.254
/ip ipsec policy
set 0 level=unique dst-address=192.168.77.0/24
/ip ipsec mode-config
add address-pool=rw-pool address-prefix-length=32 name=cfg1 split-include=192.168.77.0/24
/ip ipsec peer
add address=0.0.0.0/0 auth-method=rsa-signature certificate=bbb.nnn.org exchange-mode=ike2 generate-policy=port-strict mode-config=cfg1 passive=yes
MT client log:
14:38:52 ipsec,info new ike2 SA (I): 100.64.37.102[4500]-xxx.xxx.xxx.21[4500] spi:f47e532c3955771d:6390fccaa26a41d6
14:38:52 ipsec,info peer authorized: 100.64.37.102[4500]-xxx.xxx.xxx.21[4500] spi:f47e532c3955771d:6390fccaa26a41d6
MT server log:
14:38:51 ipsec,info new ike2 SA (R): xxx.xxx.xxx.21[4500]-121.32.126.242[23808] spi:6390fccaa26a41d6:f47e532c3955771d
14:38:52 ipsec,info peer authorized: xxx.xxx.xxx.21[4500]-121.32.126.242[23808] spi:6390fccaa26a41d6:f47e532c3955771d
What should be my next step? How to establish tunnel? How can client MT get IP address? Please help
