I use something similar to the below, scheduled to run at a regular interval. The script assumes your “WAN” interface is called “01 - WAN”. It also sets the policy src-address and dst-address to /32’s assuming an L2TP connection is encrypted between the two. You could edit this if you require
I’ve had to edit it and didn’t have time to test it I’m afraid. Let me know if you have any issues.
:local srcadd
:local sasrcadd
:global prevsasrcadd
# Get the IP from the "WAN" interface
:do {
# Change the IP from X.X.X.X/X format to X.X.X.X
:set sasrcadd [/ip address get [/ ip address find interface="01 - WAN"] address]
:for i from=( [:len $sasrcadd] - 1) to=0 do={
:if ( [:pick $sasrcadd $i] = "/") do={
:set sasrcadd [:pick $sasrcadd 0 $i]
:set srcadd ("$sasrcadd"."/32")
:set sasrcadd [:toip $sasrcadd]
:if ($sasrcadd != $prevsasrcadd) do= {
:put "IPSEC Policy Updater: Updating IPSEC Policy to use src-address=$srcadd and sa-src-address=$sasrcadd"
:log info "IPSEC Policy Updater: Updating IPSEC Policy to use src-address=$srcadd and sa-src-address=$sasrcadd"
:ip ipsec policy set [/ip ipsec policy find comment="IPSEC Policy"]
src-address=$srcadd sa-src-address=$sasrcadd
:set prevsasrcadd $sasrcadd
} else={
:put "IPSEC Policy Updater: No policy changes required"
# If the above fails, log it.
} on-error={
:put "IPSEC Policy Updater: '01 - WAN' Unable to update IPSEC address'"
:log info "IPSEC Policy Updater: '01 - WAN' Unable to update IPSEC address'"
Didn’t get a chance to post it last night… but I’ll do it tonight when I get home.
But the idea is similar to what the guy above posted… basically you have a DynDNS style service for your remote site… run a script on your main site to grab the new IP and then update the IPSec policy, proposal, etc…
Actually if you look around on the forum I may have posted it previously..
