IPsec configuration
hello
I’m having problem to understand what I need to config in the RB
for start what is Phase 1 and Phase 2 ??
this is the config the I have on his router
Phase 1
IP address:1.2.3.4
Mode: aggressive
Accept peer-id: center
Authentication method: pre-shared key
Pre-shared key: 123456789
IKE version: 1
Encryption: AES128
Authentication: SHA1
DH group: 5
Keylife: 28800 seconds
Local ID: cente
Xauth: disable
NAT traversal: enable
Keepalive frequency: 10 seconds
Dead peer detection: enable
Phase 2
Encryption: AES128
Replay detection: enable
PFS: enable
DH group: 5
Keylife: 1800 seconds
Autokey keep alive: enable
Quick mode selector source: 199.10.10.0/24
Quick mode selector destination: 172.27.63.0/24
this is all he gave me .
now , on my side this is what I have
/ip ipsec proposal
add enc-algorithms=aes-128 name=proposal1 pfs-group=modp1536
/ip ipsec peer
add address=1.2.3.4/32 dh-group=modp1536 dpd-interval=10s \
    enc-algorithm=aes-128 exchange-mode=aggressive hash-algorithm=sha1 \
    lifetime=8h nat-traversal=yes proposal-check=claim secret=\
    123456789
/ip ipsec policy
add dst-address=199.10.10.0/24 proposal=proposal1 sa-dst-address=\
    1.2.3.4 sa-src-address=12.13.14.15 src-address=192.168.63.0/24 \
    tunnel=yes
this is the NAT
add action=masquerade chain=srcnat comment=OUT
add chain=srcnat dst-address=199.10.0.0/16 src-address=192.168.63.0/24
what am I missing?
my computer is 192.168.63.12
the computer on the other side is 199.10.10.3
any help will do
Thanks ,
As explained here: http://wiki.mikrotik.com/wiki/Manual:IP/IPsec#Internet_Key_Exchange_Protocol
Phase 1 is equivalent to peer config in Mikrotik and Phase 2 is Proposal settings. Policy tells router which traffic to encrypt.
Set source address 172.27.63.0/24, remote 199.10.10.0/24 and use the rest values as they gave you.
did it , now it’s working - thanks
but now I can’t go to the internet ( no ping to google 8.8.8.:sunglasses: only to the IPSEC network
and when I add in firewall nat rule of :
the IPSEC doesn’t work
but if I add this rule after the IPSEC is working - I can go tho google 8.8.8.8
so what I need tot change ?
Thanks ,
You need to make sure that the masquerade rule is after the accept rule.
Add a rules in NAT, like this:
add chain=srcnat dst-address=199.10.0.0/16 src-address=192.168.63.0/24 action=accept
It’s very important the order of the rules, so packets for your IPSec neighbour(s) are accepted and passed over to the IPSec process before you NAT your output.
Remember, packetflow is your friend: http://wiki.mikrotik.com/wiki/Manual:Packet_Flow
:wink:
Thanks you - it’s working
I didn’t know the order of the rules have meaning
Thanks again :slight_smile:
In Mikrotik world nearly everything has a meaning. Glad to help.
