We use MT routers all the time to set up IPSEC tunnels between a client’s location and our datacenter. I’m running into an issue that I’m seeing for the first time - in my datacenter router (virtualized version 4.17 on Hyper-V) I’m getting an error in the IPSEC log stating: couldn’t find configuration. Before someone says “Hyper-V isn’t supported”, I have several (6+) of these virtual routers running on Hyper-V. It works fine with ROS ver 4.17. The only difference between this one and the others is that this is running on Server 2012 R2 and the others are running on Server 2008 R2. Both of the NIC’s transmit and receive traffic just fine. I have a virtual server tied to it and I can surf the web all day long.
Does anyone have any clue as to what is causing this error?
Here’s my configuration: (the public IP addresses have been changed to protect the innocent) Datacenter Router
Ok, I figured it out. It was being caused by what is supposed to be a transparent bridge (it appears to be routing instead of bridging) between the router in question and the outside world. I haven’t spent any time troubleshooting it yet so I’m not sure exactly what the problem is. I just bypassed the transparent bridge for now. My purpose in posting this is that if you get the “couldn’t find configuration” error, it doesn’t necessarily refer to a configuration problem INSIDE the router you’re configuring. It could be something outside of the router causing it. When I checked whatsmyip.net from the server attached to the router in question it gave me an IP address that I wasn’t expecting. So if you run into this, error message, look at all variables, not just inside the router.
Error is valid, ipsec was unable to find configuration for received ipsec packet (most likely source address was changed). If you run packet sniffer or torch you would probably see that.
Hi, I have two Mikrotik (“Office1”: RB 433AH and “Office2”:RB 1100AHx2) and trying IPSec VPN Site to Site connection, but have an error in the log even using step-by-step wiki by mikrotik
Log error: couldn’t find configuration
Office1 has seted:
LAN: 192.168.100.0/24
WAN Fictitious: 110.110.110.110/28
With configured Gateway and NAT firewall to internet access
