i’ve set up an IPSec VPN network with several 450Gs. One act as central gateway, and others are connecting to.
There are 2 networks on satellites: lan and voice, they are different instances.
the problem is: sometime some of the tunneled links got dropped. for example: on the satellite the lan or voice is NOT accessible, even pinging from central node to satellite - or vice versa (yes, using the tunneled IPs)
enabling (or disable/enable) the specific link (or rebooting the satellite) usually takes it back.
I’m interested if:
- somehow i can specify the ping watchdog for modifing source IP (and ping the remote site - if unaccessible, than reboot)
- restart ipsec instance if unaccessible (or periodically)
- any other
thanks for any ideas!
