Hi there,
I followed following howto to connect the mikrotik router to nordvpn: https://wiki.mikrotik.com/wiki/IKEv2_EAP_between_NordVPN_and_RouterOS
I don’t get any errors when entering all the information but when i look at the log with the connection it always failes with an error:
ipsec, info, new ike2 SA (I): 213.47.xxx.xxx[4500]-23.227.xxx.xxx[4500] spi:8b00cc49a08e7a98:244ecddb89505d7c
ipsec, info, account, peer authorized: 213.47.xxx.xxx[4500]-23.227.xxx.xxx[4500] spi:8b00cc49a08e7a98:244ecddb89505d7c
ipsec, error, EAP failed:
ipsec, info, killing ike2 SA: 213.47.xxx.xxx[4500]-23.227.xxx.xxx[4500] spi:8b00cc49a08e7a98:244ecddb89505d7c
Also got the following output when putting IPSec in debug mode:
20:48:26 echo: ipsec payload seen: ENC (48 bytes)
20:48:26 echo: ipsec processing payload: ENC
20:48:26 echo: ipsec,debug => iv (size 0x10)
20:48:26 echo: ipsec,debug c26d5fb8 4df9a4d4 521e54ed 8c657fb3
20:48:26 echo: ipsec,debug decrypted
20:48:26 echo: ipsec,debug,packet => decrypted packet (size 0x8)
20:48:26 echo: ipsec,debug,packet 00000008 04020004
20:48:26 echo: ipsec payload seen: EAP (8 bytes)
20:48:26 echo: ipsec processing payloads: NOTIFY (none found)
20:48:26 echo: ipsec processing payload: EAP
20:48:26 echo: ipsec,error EAP failed:
20:48:26 echo: ipsec,info killing ike2 SA: 213.47.xxx.xxx[4500]-23.227.xxx.xxx[4500] spi:995a9f4195a23eee:0094d4260cedd3ce
I am running: RouterOS v6.45.1 (stable)
Maybe someone has a basic idea what could be wrong. Thanks for the help!
