Good evening,
I’ve managed to create a tunnel between 2 remote sites. No matter what I try, I cant ping between the networks though.
Maybe you can notice something on my configuration that I haven’t.
Also I see a bunch of encryption protocols there, which of those can be called “best practice”?
Any security measures that you can propose for Site2Site configuration?
HQ:
MMMM MMMM KKK TTTTTTTTTTT KKK
MMM MMMM MMM III KKK KKK RRRRRR OOOOOO TTT III KKK KKK
MMM MM MMM III KKKKK RRR RRR OOO OOO TTT III KKKKK
MMM MMM III KKK KKK RRRRRR OOO OOO TTT III KKK KKK
MMM MMM III KKK KKK RRR RRR OOOOOO TTT III KKK KKK
MikroTik RouterOS 6.47.3 (c) 1999-2020 http://www.mikrotik.com/
[?] Gives the list of available commands
command [?] Gives help on the command and list of arguments
[Tab] Completes the command/word. If the input is ambiguous,
a second [Tab] gives possible options
/ Move up to base level
.. Move up one level
/command Use command at the base level
[admin@HQ] > export
# sep/08/2020 20:18:20 by RouterOS 6.47.3
# software id = LPP2-44E0
# model = 2011UiAS
# serial number = ************
/ip ipsec profile
add dh-group=modp1024 enc-algorithm=aes-256 name=Remote nat-traversal=no
/ip ipsec peer
add address=RemotePubIP/32 local-address=192.168.10.250 name=Remote \
profile=Remote
/ip ipsec proposal
add enc-algorithms=aes-256-cbc,aes-128-cbc,aes-128-ctr lifetime=8h name=\
"Remote Proposal"
add name=pos_pool ranges=10.10.0.100-10.10.0.200
add address-pool=pos_pool disabled=no interface=ether10 name=pos_dhcp
/port
set 0 baud-rate=9600
/tool user-manager customer
set admin access=\
own-routers,own-users,own-profiles,own-limits,config-payment-gw
add address=10.10.0.1/24 comment=LAN interface=ether2 network=10.10.0.0
add address=192.168.10.250/24 comment=WAN interface=ether1 network=192.168.10.0
add address=10.10.0.0/24 dns-server=10.10.0.1 gateway=10.10.0.1
set servers=8.8.8.8,8.8.4.4
add action=accept chain=input comment="allow L2TP VPN (ipsec-esp)" \
in-interface=ether1 protocol=ipsec-esp
add action=accept chain=input comment="allow L2TP VPN (500,4500,1701/udp)" \
dst-port=500,1701,4500 in-interface=ether1 protocol=udp
add action=accept chain=srcnat dst-address=10.10.1.0/24 log=yes src-address=\
10.10.0.0/24
add action=masquerade chain=srcnat comment="default configuration" \
ipsec-policy=out,none out-interface=ether1
/ip ipsec identity
add peer=Remote secret=****************************
/ip ipsec policy
set 0 disabled=yes
add dst-address=10.10.1.0/24 peer=Remote proposal="Remote Proposal" \
sa-dst-address=RemotePubIP sa-src-address=192.168.10.250 src-address=\
10.10.0.0/24 tunnel=yes
add distance=1 gateway=192.168.10.254
/system clock
set time-zone-name=Asia/Athens
/system identity
set name=HQ
/system logging
add topics=ipsec
/tool user-manager database
set db-path=user-manager
Client:
MMM MMM KKK TTTTTTTTTTT KKK
[admin@Remote] > export
# sep/08/2020 20:25:05 by RouterOS 6.47.3
# software id = 56LN-4XX2
# model = 750
# serial number = ***************
add name="Bridge - LAN"
/ip ipsec profile
add dh-group=modp1024 enc-algorithm=aes-256 name="HQ Profile" nat-traversal=no
/ip ipsec peer
add address=HQPubIP/32 local-address=192.168.10.250 name="HQ Peer" \
profile="HQ Profile"
/ip ipsec proposal
"HQ Proposal"
add name=pos_pool ranges=10.10.1.100-10.10.1.200
add name=lan_pool ranges=10.0.0.100-10.0.0.200
add address-pool=pos_pool disabled=no interface=ether2 name=pos_dhcp
add address-pool=lan_pool disabled=no interface="Bridge - LAN" name=lan_dhcp
/port
set 0 baud-rate=9600 name=serial0
add bridge="Bridge - LAN" interface=ether3
add bridge="Bridge - LAN" interface=ether4
add bridge="Bridge - LAN" interface=ether5
add address=10.10.1.1/24 interface=ether2 network=10.10.1.0
add address=10.0.0.1/24 interface="Bridge - LAN" network=10.0.0.0
add address=192.168.10.250/24 interface=ether1 network=192.168.10.0
add address=10.0.0.0/24 dns-server=8.8.8.8 gateway=10.0.0.1
add address=10.10.1.0/24 dns-server=8.8.8.8 gateway=10.10.1.1
add action=accept chain=srcnat dst-address=10.10.0.0/24 src-address=\
10.10.1.0/24
/ip ipsec identity
add peer="HQ Peer" secret=************************
/ip ipsec policy
set 0 disabled=yes
add dst-address=10.10.0.0/24 peer="HQ Peer" proposal="HQ" \
sa-dst-address=HQPubIP sa-src-address=192.168.10.250 src-address=\
10.10.1.0/24 tunnel=yes
/system clock
/system identity
set name=Remote
/system logging
add topics=ipsec
