IPSec established, now L2TP over it
Hi there,
I am having trouble setting up a L2TP/IPSec Client on RB5009.
I created the IPSec Tunnel and it is established.
But I do not get the L2TP to run over the established tunnel.
Here is what I did:
/interface l2tp-client
add allow=mschap2 connect-to=<server-fqdn> name=l2tp-out1 profile=L2TP user=<username>
/ppp profile
add name=L2TP use-compression=no use-encryption=yes use-mpls=yes use-upnp=no
The log is showing these entries:
12:03:47 l2tp,ppp,info l2tp-out1: terminating...
 12:03:47 l2tp,ppp,info l2tp-out1: disconnected
 12:03:47 l2tp,ppp,info l2tp-out1: initializing...
 12:03:47 l2tp,ppp,info l2tp-out1: connecting...
If someonw of you has an idea, what I can do, I will realy aprreciate it.
Thank you,
Marcus
