I am at my witts end here. I have two mikrotiks setup as office routers. I am attempting to setup an IPSEC vpn between them that that both offices can see the other network. I am getting the session established, but not able to pass traffic…
Equipment on both sides is a Mikrotik hAP Mini both running 6.41
here is the latest config attempt, and i still cannot get it to pass traffic:
R1 Ruidoso 192.168.88.0/24 1.1.1.1
ip firewall nat add chain=srcnat src-address=192.168.88.0/24 dst-address=192.168.89.0/24
ip firewall nat add chain=srcnat out-interface=ether1 action=masquerade
ip ipsec policy add src-address=192.168.88.0/24 dst-address=192.168.89.0/24 action=encrypt tunnel=yes sa-src-address=1.1.1.1 sa-dst-address=2.2.2.2
ip ipsec peer add address=2.2.2.2 exchange-mode=main secret=“somesecret”
/ip firewall raw
add action=notrack chain=prerouting src-address=192.168.88.0/24 dst-address=192.168.89.0/24
R2 Lovington 192.168.89.0/24 2.2.2.2
ip firewall nat add chain=srcnat src-address=192.168.89.0/24 dst-address=192.168.88.0/24
ip ipsec policy add src-address=192.168.89.0/24 dst-address=192.168.88.0/24 action=encrypt tunnel=yes sa-src-address=2.2.2.2 sa-dst-address=1.1.1.1
ip ipsec peer add address=1.1.1.1 exchange-mode=main secret=“somesecret”
/ip firewall filter add chain=output action=mark-connection new-connection-mark=ipsec passthrough=yes log=no log-prefix=”” ipsec-policy=out,ipsec
/ip firewall filter add chain=input action=mark-connection new-connection-mark=ipsec passthrough=yes log=no log-prefix=”” ipsec-policy=in,ipsec
/ip firewall raw
add action=notrack chain=prerouting src-address=192.168.89.0/24 dst-address=192.168.88.0/24
Session is established, i have identical installed SA’s on both sides.
R1 Firewall Rules:
add action=accept chain=input comment=“defconf: accept established,related”
add action=accept chain=input dst-port=8291 protocol=tcp src-address=
3.3.3.3/27
add action=accept chain=input src-address=2.2.2.2
add action=fasttrack-connection chain=forward comment=FastTrack
connection-mark=!ipsec connection-state=established,related
add action=accept chain=forward comment=“defconf: accept in ipsec policy”
add action=accept chain=forward comment=“defconf: accept out ipsec policy”
add action=drop chain=input comment=“defconf: drop all from WAN” in-interface=
ether1
add action=accept chain=forward comment=“defconf: accept established,related”
add action=drop chain=forward comment=“defconf: drop invalid” connection-state=
invalid
“defconf: drop all from WAN not DSTNATed” connection-nat-state=!dstnat
connection-state=new in-interface=ether1
/ip firewall mangle
add action=mark-connection chain=output comment=“Mark IPsec connections”
ipsec-policy=out,ipsec new-connection-mark=ipsec passthrough=yes
add action=mark-connection chain=input ipsec-policy=in,ipsec
add chain=srcnat dst-address=192.168.89.0/24 src-address=192.168.88.0/24
add action=masquerade chain=srcnat comment=“defconf: masquerade” out-interface=
ether1
/ip firewall raw
add action=notrack chain=prerouting dst-address=192.168.89.0/24 src-address=
192.168.88.0/24
192.168.88.0/24
R2 Firewall Rules:
“defconf: accept established,related,untracked” connection-state=
3.3.3.3/27
add action=accept chain=input src-address=1.1.1.1
add action=drop chain=input comment=“defconf: drop invalid” connection-state=
invalid
add action=accept chain=input comment=“defconf: accept ICMP” protocol=icmp
add action=drop chain=input comment=“defconf: drop all not coming from LAN”
in-interface-list=!LAN
add action=fasttrack-connection chain=forward comment=“defconf: fasttrack”
connection-state=established,related disabled=yes
“defconf: accept established,related, untracked” connection-state=
invalid
connection-mark=!ipsec connection-state=established,related disabled=yes
/ip firewall mangle
add chain=srcnat dst-address=192.168.88.0/24 src-address=192.168.89.0/24
add action=masquerade chain=srcnat comment=“defconf: masquerade” ipsec-policy=
out,none out-interface-list=WAN
add action=dst-nat chain=dstnat dst-address=68.233.148.25 dst-port=443
protocol=tcp to-addresses=192.168.98.20 to-ports=443
add action=masquerade chain=srcnat dst-address=192.168.89.20 dst-port=443
out-interface=bridge protocol=tcp src-address=192.168.89.0/24
/ip firewall raw
add action=notrack chain=prerouting dst-address=192.168.88.0/24 src-address=
192.168.89.0/24
192.168.89.0/24
Any help would be greatly appeciated, thank you!!!
