ipsec: failure to add policy
Hello, I’m trying to setup IPSec on Mikrotik RouterOS 6.6 but it isn’t coming up, what is wrong with my setup? Why can’t the client find any policies?
/ip ipsec mode-cfg
add address-pool=vpn-pool name=home-vpn
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-128
/ip ipsec peer
add auth-method=pre-shared-key-xauth enc-algorithm=aes-128 generate-policy=
port-strict mode-cfg=home-vpn nat-traversal=yes passive=yes secret=megasecret send-initial-contact=no
add name=LAN_POOL ranges=192.168.55.65-192.168.55.126
add name=vpn-pool ranges=192.168.55.128/27
30/11/13 16:04:36,727 racoon[456]: >>>>> phase change status = Phase 1 established
30/11/13 16:04:36,727 racoon[456]: IKE Packet: receive success. (MODE-Config).
30/11/13 16:04:36,727 configd[19]: IPSec Network Configuration started.
30/11/13 16:04:36,727 configd[19]: IPSec Network Configuration: INTERNAL-IP4-ADDRESS = 192.168.55.159.
30/11/13 16:04:36,727 configd[19]: IPSec Network Configuration: INTERNAL-IP4-MASK = 255.255.255.0.
30/11/13 16:04:36,727 configd[19]: IPSec Network Configuration: INTERNAL-IP4-DNS = 192.0.2.2.
30/11/13 16:04:36,727 configd[19]: IPSec Network Configuration: INTERNAL-IP4-DNS = 192.0.2.1.
30/11/13 16:04:36,727 configd[19]: Failed to add policy. Number of policies processed 0 (with 0 drained).
30/11/13 16:04:36,727 configd[19]: IPSec Controller: IPSecInstallPolicies failed ‘no policies found’
30/11/13 16:04:36,727 configd[19]: IPSec Phase1 established.
30/11/13 16:04:37,142 Console[459]: setPresentationOptions called with NSApplicationPresentationFullScreen when there is no visible fullscreen window; this call will be ignored.
30/11/13 16:04:41,019 xpcproxy[461]: assertion failed: 13A603: xpcproxy + 3438 [EE7817B0-1FA1-3603-B88A-BD5E595DA86F]: 0x2
30/11/13 16:04:49,988 com.apple.usbmuxd[64]: _SendAttachNotification Device bc:3b:af:09:c7:46@fe80::be3b:afff:fe09:c746._apple-mobdev2._tcp.local. has already appeared on interface 4. Suppressing duplicate attach notification.
30/11/13 16:04:53,572 configd[19]: IPSec disconnecting from server 81.x.x.x
30/11/13 16:04:53,572 racoon[456]: IPSec disconnecting from server 81.x.x.x
30/11/13 16:04:53,572 racoon[456]: IKE Packet: transmit success. (Information message).
30/11/13 16:04:53,573 racoon[456]: IKEv1 Information-Notice: transmit success. (Delete ISAKMP-SA).
30/11/13 16:04:53,573 racoon[456]: failed to send vpn_control message: Broken pipe
30/11/13 16:04:53,574 racoon[456]: glob found no matches for path “/var/run/racoon/*.conf”
30/11/13 16:04:53,574 racoon[456]: IPSec disconnecting from server 81.x.x.x
30/11/13 16:04:53,576 configd[19]: network changed.
30/11/13 16:04:53,581 configd[19]: network changed.
Probably because you have not defined any.
Using ‘generate-policy’ on client side does not make any sense to me.
Mikrotik is not the client, it’s the concentrator (server)
