IPSEC & Firewall
Morning,
I’ve setup IPSEC for a VPN between my office and the datacentre. My plan is to use a domain controller I have built in the datacentre and then remove the one I have on site.
I just need to create a trust between the two.
All of our computers can join the new DC in the datacentre, they can also ping the datacentre. This is fine. However, the DC in the datacentre cannot ping any of the computers or DC here on site.
How do I get it to talk both ways? I’ve never setup a VPN or IPSEC before, and have very little experience with firewalls, especially on mikrotiks as I’ve never used one.
Anything you can suggest? Anything I may have missed? Do I need to add a firewall rule in to allow communication both ways? Or is there a way in the mikrotik router that I can check for packet loss from certain IP addresses (i.e the data centre’s IP to my routers)?
You forgot to show the configuration that you have made.
Maybe it has some form of NAT between your network and the datacentre?
You should avoid that as it makes things much more complicated…
