Don’t know who made the script below (thank you) just found it using search on this forum. I think it works, didn’t tested yet.
I just need your help to change it a bit for my needs.
I need to add this: after the Installed-SA are flushed it should ping 10.0.1.2 five times.
Thank you.
:local IPWatchServer 10.0.1.2
:local OutInterface bridge-lan
:if ([/ping interface=$OutInterface $IPWatchServer count=4]<3) do={
/ip ipsec installed-sa flush sa-type=all
:log info "IPSEC tunnel with XO is down: Flushing Installed SA !!!"
} else={
:log info "IPSEC tunnel with XO is OK !"
