Hello everyone,
I have a LAN to LAN IPSec connection running, with one client having a dynamic IP. The setup worked like a charm for quite some time, the router with dynamic WAN-IP sends the initial connections, the router with static WAN-IP on the other side has “generate policy” enabled.
With 2 subnets from 2 different remote peers everything worked fine, but now one of the remote peers should connect 2 subnets, but only one policy is generated and therefore only one subnet works.
I already thought about some masq+routing rules to solve the issue, but perhabs there are better solutions.
Any ideas?
Thanks in advance,
sap
