HOW I MISS OPEN VPN!!!
Now that I got that out of my system.
Is there a list of all the quirks about Mikrotik’s use of ipsec?
Things so far.
If you have to DMZ your router and don’t have a public IP at the Mikrotik. l2tp Ipsec vpn fails from external clients.
If you are VPNing to a router with a public IP address… from some cellular providers. l2tp IPSEC fails.
If you have 2 subnets on you router that you want to have policies for… and you are coming from a firebox (I think that is what the other side IT guy said)…
You have to have the policies work on different WAN IPs on the TIk???
If you had say network 192.168.101.0/24 and 172.16.16.0/24 on your TIK and are connecting Ipsec tunnels… I could get one or the other to pass.
Fortunatly… I had a block of static IPs for the Tik. So I used 1 WAN IP for each policy. Problem solved.
/ip ipsec policy
add comment="Hardware Site2Site" dst-address=172.20.3.0/24 proposal=Watchbox \
sa-dst-address=xxx.xxx.xxx.1 sa-src-address=xxx.xxx.xxx.97 src-address=\
192.168.101.0/24 tunnel=yes
add comment="Main Network Site2Site" dst-address=172.20.3.0/24 proposal=\
Watchbox sa-dst-address=xxx.xxx.xxx.1 sa-src-address=xxx.xxx.xxx.98 \
src-address=172.20.4.0/24 tunnel=yes
