I have a strange issue where I create a peer and test the tunnel and everything’s working.
I disconnect the device (Digi modem) and replug it 24h later and the VPN wont come up with an error :
Phase 1 negotiation failed due to time up.
I have a routerOS 6.30 running on VMware with fault Tolerence
Here’s my peer config :
3 ;;; 10.69.0.5
;;; Unsafe configuration, suggestion to use certificates
address=0.0.0.0/0 local-address=0.0.0.0 passive=no port=500 auth-method=pre-shared-key secret="MY-SECRET-KEY" generate-policy=port-strict policy-template-group=Digi exchange-mode=aggressive
send-initial-contact=no nat-traversal=no proposal-check=obey hash-algorithm=sha1 enc-algorithm=aes-256 dh-group=modp1024 lifetime=1d lifebytes=0 dpd-interval=1h dpd-maximum-failures=5
Here’s my Policy
2 T group=Digi src-address=0.0.0.0/0 dst-address=0.0.0.0/0 protocol=all proposal=Digi template=yes
here’s my proposal
name="Digi" auth-algorithms=sha1 enc-algorithms=aes-256-cbc lifetime=1d pfs-group=modp1024
My modem are connecting using a cellular modem and have dynamic IP.
Anyone have an idea where he didnt seem to rekey?
Regards
