IPsec IKEv2 multiple Peers
Having issue on RB4011iGS (6.45.6) - only one peer works with IKE2 option enabled.
If enabling more than one - ros can’t distinguish between peers and throws out: ipsec, error identity not found for peer:…
At the same time in Peers getting: – This entry is unreachable (when more than one peer activated).
Peers are all behind NAT different external IP’s (or sometimes the same), running strongswan and Win10. With Strongswan “responder” side - all runs flawlessly. With Mikrotik - one peer is the limit.
Are there any ideas on how to solve this?
