Hi, I have a weird problem with the setup shown above.
- I can ping and traceroute from both hosts pc’s and routers to either of the LAN sides.
- I can browse from 192.168.1.0/24 to 192.168.5.0/27 everything like NAS server , samba server, login to asterisk which is locate at 192.168.5.0/27 and make calls through BUT
- I CAN’T browse anything from 192.168.5.0/27 to 192.168.1.0/24 , like the internal webpage of the other’s side modem 192.168.1.1 or other side Mikrotik.
In connections tab in firewall it’s says established seen reply and assured but can’t get through. Only the other way around works.
The funny thing is since I am running an IPsec server for site-to-site and roadwarriors, if I enable the site-to-site tunnel and then a roadwarrior client connects , he can access the 192.168.1.0/24 network from his side through his roadwarrior tunnel which passes through the site-to-site tunnel! I have disabled the firewall in mikrotik , enable it again , none seems to work.
My Server Side (192.168.5.0/27 lan) setup is:
add fast-forward=no name="bridge to W724" protocol-mode=none
set [ find default-name=ether1 ] advertise=1000M-full name=xxx
set [ find default-name=ether2 ] advertise=1000M-full name=xxx
set [ find default-name=ether3 ] advertise=1000M-full name=xxx
set [ find default-name=ether4 ] advertise=1000M-full name=xxx
set [ find default-name=ether5 ] advertise=1000M-full name=xxx
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 enc-algorithms=aes-256-gcm pfs-group=none
add name=VPN-Pool ranges=10.10.10.10-10.10.10.15
/ip ipsec mode-config
add address-pool=VPN-Pool address-prefix-length=32 name=cfg1 system-dns=no
add address=192.168.5.62/27 interface="bridge to W724" network=192.168.5.0
set allow-remote-requests=yes servers=192.168.5.1
/ip firewall address-list
add address=0.0.0.0/8 comment="Self-Identification [RFC 3330]" list=bogons
add address=10.0.0.0/8 comment="Private[RFC 1918] - CLASS A # Check if you need this subnet before enable it" disabled=yes list=bogons
add address=127.0.0.0/8 comment="Loopback [RFC 3330]" list=bogons
add address=169.254.0.0/16 comment="Link Local [RFC 3330]" list=bogons
add address=172.16.0.0/12 comment="Private[RFC 1918] - CLASS B # Check if you need this subnet before enable it" list=bogons
add address=192.168.0.0/16 comment="Private[RFC 1918] - CLASS C # Check if you need this subnet before enable it" disabled=yes list=bogons
add address=192.0.2.0/24 comment="Reserved - IANA - TestNet1" list=bogons
add address=192.88.99.0/24 comment="6to4 Relay Anycast [RFC 3068]" disabled=yes list=bogons
add address=198.18.0.0/15 comment="NIDB Testing" list=bogons
add address=198.51.100.0/24 comment="Reserved - IANA - TestNet2" list=bogons
add address=203.0.113.0/24 comment="Reserved - IANA - TestNet3" list=bogons
add address=224.0.0.0/4 comment="MC, Class D, IANA # Check if you need this subnet before enable it" list=bogons
add address=192.168.5.0/27 list=support
add address=192.168.1.0/24 list=support
add action=drop chain=input comment="Drop to bogon list" log=yes src-address-list=bogons
add action=drop chain=input comment="Drop Invalid connections" connection-state=invalid log=yes
add action=accept chain=forward connection-state=established,related,new dst-address=192.168.5.0/27 src-address=192.168.1.0/24
add action=accept chain=forward connection-state=established,related,new dst-address=192.168.1.0/24 src-address=192.168.5.0/27
add action=accept chain=input dst-port=4500 protocol=udp
add action=accept chain=input dst-port=500 protocol=udp
add action=accept chain=input protocol=ipsec-esp
add action=accept chain=input comment="Allow Established and Related connections" connection-state=established,related in-interface="bridge to W724" log=yes src-address=192.168.1.0/24
add action=accept chain=forward connection-state=established,related in-interface="bridge to W724" src-address=192.168.5.0/27
add action=accept chain=forward connection-nat-state="" in-interface="bridge to W724" src-address=10.10.10.10-10.10.10.100
add action=add-src-to-address-list address-list=Syn_Flooder address-list-timeout=30m chain=input comment="Add Syn Flood IP to the list" connection-limit=30,32 protocol=tcp tcp-flags=syn
add action=drop chain=input comment="Drop to syn flood list" src-address-list=Syn_Flooder
add action=add-src-to-address-list address-list=Port_Scanner address-list-timeout=1w chain=input comment="Port Scanner Detect" protocol=tcp psd=21,3s,3,1
add action=drop chain=input comment="Drop to port scan list" src-address-list=Port_Scanner
add action=jump chain=input comment="Jump for icmp input flow" disabled=yes jump-target=ICMP protocol=icmp
add action=drop chain=input comment="Block all access to the winbox - except to support list # DO NOT ENABLE THIS RULE BEFORE ADD YOUR SUBNET IN THE SUPPORT ADDRESS LIST" dst-port=8291 protocol=tcp \
src-address-list=!support
add action=jump chain=forward comment="Jump for icmp forward flow" jump-target=ICMP protocol=icmp
add action=drop chain=forward comment="Drop to bogon list" dst-address-list=bogons
add action=add-src-to-address-list address-list=spammers address-list-timeout=3h chain=forward comment="Add Spammers to the list for 3 hours" connection-limit=30,32 dst-port=25,587 limit=30/1m,0:packet \
protocol=tcp
add action=drop chain=forward comment="Avoid spammers action" dst-port=25,587 protocol=tcp src-address-list=spammers
add action=accept chain=input comment="Accept DNS - UDP" log=yes port=53 protocol=udp
add action=accept chain=input comment="Accept DNS - TCP" port=53 protocol=tcp
add action=accept chain=input comment="Accept to established connections" connection-state=established log=yes
add action=accept chain=input comment="Accept to related connections" connection-state=related log=yes
add action=accept chain=input comment="Full access to SUPPORT address list" src-address-list=support
add action=drop chain=input comment="Drop anything else! # DO NOT ENABLE THIS RULE BEFORE YOU MAKE SURE ABOUT ALL ACCEPT RULES YOU NEED" log=yes
add action=accept chain=ICMP comment="Echo request - Avoiding Ping Flood" icmp-options=8:0 limit=1,5:packet log=yes protocol=icmp
add action=accept chain=ICMP comment="Echo reply" icmp-options=0:0 protocol=icmp
add action=accept chain=ICMP comment="Time Exceeded" icmp-options=11:0 protocol=icmp
add action=accept chain=ICMP comment="Destination unreachable" icmp-options=3:0-1 protocol=icmp
add action=accept chain=ICMP comment=PMTUD icmp-options=3:4 protocol=icmp
add action=drop chain=ICMP comment="Drop to the other ICMPs" log=yes protocol=icmp
add action=jump chain=output comment="Jump for icmp output" jump-target=ICMP log=yes protocol=icmp
add action=accept chain=srcnat dst-address=192.168.1.0/24 log=yes src-address=192.168.5.0/27
add action=accept chain=srcnat dst-address=192.168.5.0/27 log=yes src-address=192.168.1.0/24
add action=masquerade chain=srcnat log=yes
/ip ipsec peer
add auth-method=rsa-signature certificate=mt-server dh-group=ecp384,modp2048 dpd-interval=5s enc-algorithm=aes-256 exchange-mode=ike2 generate-policy=port-strict hash-algorithm=sha256 mode-config=cfg1 \
passive=yes send-initial-contact=no
/ip ipsec policy
set 0 disabled=yes
add dst-address=192.168.1.0/24 src-address=192.168.5.0/27 template=yes
add comment=RoadWarrior dst-address=10.10.10.0/24 src-address=0.0.0.0/0 template=yes
add distance=1 gateway=192.168.5.2
And the client (192.168.1.0/24) side:
/ip ipsec proposal
add address=192.168.1.254/24 interface=ether2 network=192.168.1.0
set allow-remote-requests=yes servers=192.168.1.1
add action=accept chain=input disabled=yes
add action=accept chain=forward disabled=yes
add action=accept chain=output disabled=yes
add action=accept chain=forward connection-state=established,related,new dst-address=192.168.5.0.27 \
in-interface=ether2 src-address=192.168.1.0/24
add action=accept chain=forward connection-state=established,related,new dst-address=192.168.1.0/24 \
in-interface=ether2 src-address=192.168.5.0/27
add action=accept chain=srcnat dst-address=192.168.5.0/27 src-address=192.168.1.0/24
add action=accept chain=srcnat dst-address=192.168.1.0/24 src-address=192.168.5.0/27
/ip ipsec peer
add address=2.86.XXX.XXX/32 auth-method=rsa-signature certificate=mt-ikaria dh-group=ecp384 dpd-interval=20s \
enc-algorithm=aes-256 exchange-mode=ike2 generate-policy=port-strict hash-algorithm=sha256 mode-config=\
request-only notrack-chain=prerouting
/ip ipsec policy
set 0 disabled=yes dst-address=192.168.5.0/27 src-address=192.168.1.0/24
add dst-address=192.168.5.0/27 level=unique sa-dst-address=2.86.XXX.XXX sa-src-address=0.0.0.0 src-address=\
192.168.1.0/24 tunnel=yes
add distance=1 gateway=192.168.1.1
