I have a brand new Mikrotik RB4011gs and latest RouterOS 6.48.1 behind my (W)ISP antenna/router in DMZ zone (unfortunately I can not manage directly PPPoE connection…negotiating about that) and with a public dynamic IP. There are no other devices connected to ISP router, and all the traffic is forwarded (DMZ) to Mikrotik ether1 WAN port.
Internet <-----> ISP Router <------> Mikrotik <-----> LAN(s)
I can setup an OpenVPN TCP server in Mikrotik (I know, not optimized and slow). However, I would like to have a IPSec IKEv2 or an L2TP/IPsec VPN server to access my lan remotely. I started with the tutorials here:
From logs, looks ipsec connects correctly, I can see the active peer connected, PH2 phase looks ok, SAs enstablishes, the Android device used for test acquires a correct IP from the VPN pool…but no traffic. Also, from firewall rules I can see packets on 500, 4500 ports but not on on ipsec-esp rule. The SA source address is the private IP of Mikrotik toward WAN port (ether1) connected to ISP router. SA dst. address is the public IP of the android phone. PH2 state enstablished, PH2 count = 1, Src address = 0.0.0.0\0 dst. address = the private address of android device within the pool
Do you have any suggestion? Is it possible in general to have IPSec server under double nat as above?
Yes, sure. The number of NATs doesn’t matter (provided that all of them work properly).
That is no surprise. If there is at least one NAT on the path between the peers, the ESP gets encapsulated into UDP, and the encapsulation (payload → ESP → UDP), as well as decapsulation in the reverse order, is done in a single step by the IPsec protocol stack, so the ESP packets are invisible to the firewall (unlike the UDP transport ones and the payload ones).
I would say the reason is either firewall misconfiguration or something broken in 6.48.1. You mention Android as an initiator but you haven’t explicitly specified that you use IKEv2. The src-address and dst-address of the policy suggest that you do, so do you run some recent Android version which supports IKEv2 natively or do you use a 3rd party VPN application, like Strongswan?
You also haven’t shown any configuration export from the MIkrotik, see my automatic signature below for a micro-howto.
When you try to access some web page from the Android via the VPN, does /ip ipsec installed-sa print interval=1s show that the Android → Mikrotik SA receives some packets? If it does, it is a firewall issue; if it doesn’t, it may be a routing issue at Android side or the NAT detection may have failed. Do the src-address and dst-address of the installed SAs show only the public IP address of the Android device or also the port?
I’m using native Android 10 IPSec IKEv2 support on Samsung S9+
Here is the Mikrotik config exported (with some sensitive data removed )
# feb/15/2021 08:50:37 by RouterOS 6.48.1
# software id = xxxxxx
# model = RB4011iGS+
# serial number = xxxxxxxx
add admin-mac=XX:XX:XX:XX:XX:XX auto-mac=no comment=defconf name=bridge
set [ find default-name=ether1 ] name=ether1-WAN
set 0 default-vlan-id=0
set 1 default-vlan-id=0
set 2 default-vlan-id=0
set 3 default-vlan-id=0
set 4 default-vlan-id=0
set 5 default-vlan-id=0
set 6 default-vlan-id=0
set 7 default-vlan-id=0
set 8 default-vlan-id=0
set 9 default-vlan-id=0
set 10 default-vlan-id=0
set 11 default-vlan-id=0
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] supplicant-identity=xxxxxxxxx
/ip ipsec policy group
add name=ipsec-group
/ip ipsec profile
set [ find default=yes ] enc-algorithm=aes-256,aes-192,aes-128 hash-algorithm=\
sha256
add enc-algorithm=aes-256,aes-192,aes-128 name=ipsec-profile
/ip ipsec peer
add exchange-mode=ike2 local-address=192.168.0.253 name=user1 passive=yes \
profile=ipsec-profile send-initial-contact=no
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256,sha1 enc-algorithms=\
aes-256-cbc,aes-256-gcm,aes-192-cbc,aes-192-gcm,aes-128-cbc,aes-128-gcm \
lifetime=8h
add enc-algorithms="aes-256-cbc,aes-256-ctr,aes-256-gcm,aes-192-cbc,aes-192-ctr,\
aes-192-gcm,aes-128-cbc,aes-128-ctr,aes-128-gcm" lifetime=8h name=\
ipsec-proposal pfs-group=none
add name=dhcp ranges=192.168.178.2-192.168.178.254
add name=vpn-pool ranges=192.168.8.10-192.168.8.99
add name=ipsec-pool ranges=192.168.100.2-192.168.100.99
add address-pool=dhcp disabled=no interface=bridge lease-time=2h name=defconf
/ip ipsec mode-config
add address-pool=ipsec-pool address-prefix-length=32 name=ipsec-config \
split-include=0.0.0.0/0 system-dns=no
/ppp profile
set *0 use-ipv6=default
add dns-server=192.168.8.250 local-address=192.168.8.250 name=vpn-profile \
remote-address=vpn-pool use-compression=no use-encryption=required \
use-ipv6=default
/system logging action
set 0 memory-lines=10000
add bridge=bridge comment=defconf interface=ether6
add bridge=bridge comment=defconf interface=ether7
add bridge=bridge comment=defconf interface=ether8
add bridge=bridge comment=defconf interface=ether9
add bridge=bridge comment=defconf interface=ether10
add bridge=bridge comment=defconf interface=sfp-sfpplus1
add comment=defconf interface=ether1-WAN list=WAN
/interface ovpn-server server
set auth=sha1 certificate=server-certificate cipher=aes192,aes256 \
default-profile=vpn-profile enabled=yes require-client-certificate=yes
add address=192.168.178.1/24 comment=defconf interface=bridge network=\
192.168.178.0
add address=192.168.0.253/24 interface=ether1-WAN network=192.168.0.0
/ip cloud
set ddns-enabled=yes ddns-update-interval=5m
/ip dhcp-client
add address=192.168.178.0/24 comment=defconf gateway=192.168.178.1 netmask=24
established,related,untracked
add action=accept chain=input comment="allow OpenVPN" dst-port=1194 protocol=\
tcp
add action=accept chain=input in-interface-list=dynamic protocol=tcp \
src-address=192.168.8.0/24
add action=accept chain=input comment="L2TP/IPSec rules" dst-port=500,4500 \
protocol=udp
add action=accept chain=input protocol=ipsec-esp
ipsec-policy=in,ipsec
ipsec-policy=out,ipsec
invalid
add action=drop chain=forward comment="defconf: drop invalid" connection-state=\
invalid
add action=drop chain=forward comment="defconf: drop all from WAN not DSTNATed" \
connection-nat-state=!dstnat connection-state=new in-interface-list=WAN
in-interface-list=!LAN
out-interface-list=WAN src-address=192.168.178.0/24
/ip ipsec identity
add generate-policy=port-strict mode-config=ipsec-config peer=user1 \
policy-template-group=ipsec-group remote-id=key-id:user1
/ip ipsec policy
add dst-address=192.168.100.0/24 group=ipsec-group proposal=ipsec-proposal \
src-address=0.0.0.0/0 template=yes
/ip ipsec settings
set accounting=no
add distance=1 gateway=192.168.0.254
/ppp secret
add name=mobile profile=vpn-profile service=ovpn
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=xxxxxxxxx
/system ntp client
set enabled=yes primary-ntp=108.61.73.243 secondary-ntp=138.68.201.49
/tool mac-server
/tool mac-server mac-winbox
I included also OpenVPN server configuration…that works perfectly.
Yes, I can see packets from Android to Mikrotik. But I can not see what is wrong on firewall…
Flags: H - hw-aead, A - AH, E - ESP
0 HE spi=an hex number src-address=x.x.x.x:4255 dst-address=192.168.0.253:4500
state=mature enc-algorithm=aes-gcm enc-key-size=288
enc-key="something long :)"
addtime=feb/15/2021 09:06:21 expires-in=7h58m33s add-lifetime=6h24m/8h
current-bytes=47085 current-packets=228 replay=128
1 HE spi=another hex number src-address=192.168.0.253:4500 dst-address=x.x.x.x:4255
enc-key="other boring long stuff :)"
add-lifetime=6h24m/8h replay=128
-- [Q quit|D dump|C-z pause]
I also tried to remove all the “drop” rules from firewall (so, no firewall ) with the same result…ports on the remote android side is also shown.
A question: the IKEv2 tunnel should create also a dynamic routing rule when establishes? (similar to the OpenVPN server…). Meanwhile when an openvpn connection sets I can see a routing dynamic rule on the list, I don’t see the same for the IPSec IKEv2 connection…
Not really funny, the filth from the net may be incredibly fast to squat in (been there, seen that).
Nope. With IPsec on Mikrotik, the traffic to be sent via an IPsec SA is chosen by traffic selectors, which override the result of the “normal” routing. So first a packet is routed using the normal routing, and if the result of the routing is that the packet should be sent out via some interface, its headers are matched against the traffic selectors of all existing IPsec policies; the first match eventually found diverts the packet to the SA associated to the respective policy.
The actual issue is that your one and only action=masquerade rule is too selective: it matches on src-address=192.168.178.0/24, whereas the IPsec clients get their addresses from ipsec-pool with ranges=192.168.100.2-192.168.100.99. Hence the initial packet sent by the Android client to some public address does not get src-nated as the router forwards it to the internet, and therefore either your ISP drops it as an illegal one, or such packet does make it to the server but the server responds to 192.168.100.x and the response is routed according to its local routing for this address, so definitely not back to your router.
On the other hand, you have to exclude packets towards 192.168.100.2-192.168.100.99 (or 192.168.100.0/24 to make it simple) from being src-nated (or masqueraded, the difference between the two is not relevant here) if you want to be able to initiate connections to the IPsec client device acting as a server (i.e. to ping it). The NAT rules are only applied on the initial packet of each connection; the decision taken for the initial packet is stored in the context of the connection, and all subsequent packets of that connection are treated the same way (or inversely, depending on their direction).
I tried to both relax masquerade rule for non IPSec traffic (no src-address specified) and also to set up a dedicated masquerade for the IPSec IP pool (similar to what shown here: https://mum.mikrotik.com/presentations/MY19/presentation_7008_1560543676.pdf ). I can see traffic hitting the masquerade rule in the NAT, but no webpage or other traffic will pop up succefully on the Android client, and of course no ping to internal LAN. I played around with the configuration showed also in the PDF, without any luck:
On the other hand, you have to exclude packets towards > 192.168.100.2-192.168.100.99 > (or > 192.168.100.0/24 > to make it simple) from being src-nated (or masqueraded, the difference between the two is not relevant here) if you want to be able to initiate connections to the IPsec client device acting as a server (i.e. to ping it). The NAT rules are only applied on the initial packet of each connection; the decision taken for the initial packet is stored in the context of the connection, and all subsequent packets of that connection are treated the same way (or inversely, depending on their direction).
Not sure how to obtain this… can you give me an example configuration of that rule?
Hm. The masquerade rule is definitely not related to pinging a LAN host, so something more must be wrong. So run /tool sniffer quick ip-address=8.8.4.4
on the Mikrotik, ping 8.8.4.4 from the phone, and see how far the request makes it and whether a response comes (and how far it makes it). Then do the same for an address on LAN which you can ping from the router itself.
Place a rule chain=srcnat action=accept dst-address=192.168.100.0/24 before (above) the masquerade ones. On a command-line, an additional parameter place-before=x works when adding a rule, and /ip firewall nat move x destination=y works when you want to change order of already existing rules; on the GUIs, drag and drop is used to change the order of rules.
Or add ipsec-policy=out,none to the masquerade rule, which is however a less selective way and hence not suitable for all situations (sometimes you need the reverse, to masquerade/srcnat some traffic in order that it would match a policy).
Something is happening…wrong. Google DNS ping generate traffic back/forth ether1 interface (mac addresses between mirkotik and ISP router), but no ping on the Android phone. Ping to LAN comes to ether1—> bridge ----> ether2 LAN interface and reverse. But still no ping succeded on the Android phone. Crazy.
Place a rule > chain=srcnat action=accept dst-address=192.168.100.0/24 > before (above) the masquerade ones. On a command-line, an additional parameter > place-before=x > works when adding a rule, and > /ip firewall nat move x destination=y > works when you want to change order of already existing rules; on the GUIs, drag and drop is used to change the order of rules.
Or add > ipsec-policy=out,none > to the masquerade rule, which is however a less selective way and hence not suitable for all situations (sometimes you need the reverse, to masquerade/srcnat some traffic in order that it would match a policy).
So in the Google DNS case, you can see the IPsec payload decapsulated from the transport packet to arrive via ether1 and be sent via ether1 again, then the response to arrive from ether1, and that’s all, correct? If so, it is a correct behaviour, because the payload packet is not visible in sniffer before geting encrypted and encapsulated. Given that the SA for Mikrotik->Android direction doesn’t count packets, it means the response packet got lost somewhere. Since there is a rule in your firewall, which says “accept forwarded packets matching an outgoing IPsec policy”, can you see that rule to count as you are pinging (/ip firewall filter print stats interval=1s)? And can you see the installed-sa to count, now after the change of the masquerade rule?
It could not help with the above, it should only have allowed you to ping the phone from the Mikrotik itself. So also here, if you ping this way, can you see the installed-sa in the Mikrotik-Android direction to count?
Correct for the Google DNS behavior on ether1, but ping still fails on Android.
However, the outgoing rules is never hitted, only the input ipsec one. But, I can see traffic outgoing in the SA from local to remote Android device.
When I ping from Android to Mikrotik LAN, same.
I’m surprised that the action=accept ipsec-policy=out,ipsec rule does not count whereas the mikrotik->android installed-sa does.
But if I read you right, both installed-sa now count when you ping from the Android, and don’t otherwise? Or I have missed something?
If you run /tool sniffer ip-address=the.public.ip.of.the.phone, and ping anything (Google DNS or LAN host) from the phone, can you see packets to both arrive and leave?
You have read correctly: both counters increases, but the firewall rules is not hitted.
The packet sniffing tools sees packets in both directions from the public Android IP and the ether1 wan interface IP (192.168.0.253), not only pinging, but probably from other services on my android phone trying to communicate through the tunnel…
(God, when RouterOS 7 with Wireguard will be ready )
Well… so the IPsec transport packets are now going in both directions, installed-sa are counting - it sounds to me like an Android problem, or a problem of incorrect encryption and/or authentication at Mikrotik side, making the received packets at Android side undecipherable.
To find out which assumption is correct, using some other RouterOS version than 6.48.1 may be the simplest way. For me, IKEv2 works fine in 6.46.8. And the multiple NAT has nothing to do with it, except if the native IKEv2 in Android was equally stupid as the one in Windows, which doesn’t like NAT at responder side by default and you have to tell it using registry to accept it. But the Windows one at least claims the error already during Phase 1. And you can fool that by attaching the public IP to a port-less bridge interface on the Mikrotik, setting the local-address of the /ip ipsec peer row to that address, and doing dst-nat from 192.168.0.253 “back” to the public IP, but I’m not sure how the public IP detection of /ip cloud will react on that.
The advantage of the native Android client seems to be the support of PSK authentication, so if you want to substitute it by Strongswan, you’ll have to create the certificates (hint: Strongswan cares abot Subject Alt Name, not about Common Name).
Regarding Wireguard, where’s the client address assignment by server?
But still I can’t justify why the output ip filter rule is not hitted…even if packets count and sniffer see rx/tx flows…
I was aware about that issue with Android, but since IKEv2 tunnel phases 1 and 2 were ok, sounds strange that later Android can not decode packets… Encryption keys are set up correctly for both installed SAs…
There is no Wireguard yet on 6.48.1. I have actually an Rpi 4 on the LAN behind the Mikrotik that works as WG server: it assigns the remote IP and then I forward selected traffic with iptables from Rpi toward LAN/WAN…Rough, but worked flawlessy after 5 minutes. It’s my actual main VPN system (I tried openvpn on Mikrotik but it’s sloooooow…and tcp only).
Still with 6.48.1, i tried also to set up strongswan on android and RSA certificate identity. No luck with that solution too. Even if fqdn server identification works ok, client can not login with the same erro…
identity not found for peer: DER DN: client.(something)
the client.(something) is the same common name on the certificate used.
Looks something is really broken in IPSec and 6.48.1 at this point.
Show me the /certificate print detail (assuming you’ve created the certificate for the Strongswan client on the 4011 so it will be there as well) and the /ip ipsec export hide-sensitive.
Using IP address together with type fqdn as peer identity is not a good idea as the Strongswan expects the type of the Subject-Alt-Name of the certificate to match the identity type. So if identity type is fqdn, the subject alt name type must be DNS; if identity type is address, the subject alt name type must be IP. Unless something has changed recently, if the Subject-Alt-Name of the server certificate is empty, like in your case, Strongswan will consider the certificate invalid to authenticate the server; I’m also not sure whether Strongswan doesn’t require the key-usage list to contain ipsec-end-system and/or ipsec-tunnel. Mikrotik, somehow oddly, requires tls-client and tls-server items to consider the certificate applicable for IPsec authentication of an initiator and responder, respectively.
But all the above is related to the Strongswan side; I never set my-id at the identity rows with auth-mode=digital-signature, which means I don’t know how doing so affects matching of the peer’s ID to the /ip ipsec identity rows. Try to set my-id to auto and see how far you get that way.
Very good explanation, thanks!!. I was able to fix the issues with certificates…but the behavior is exactly the same as with the pre-shared key solution and the native Android client. No LAN ping, no WAN access, similar packet flows and packet sniffer results…
That pretty much excludes issues at the Android end. So I’d myself try 6.46.8 before digging further. Not because that version is special in some way but because I know IKEv2 works on it, whereas I haven’t tested 6.47.9 nor 6.48.1 yet.
