IPSec Installed-sa
I need help. I need to replace NETGEAR FVG318 router with Mikrotik RouterBOARD.
I need help transferring IPSec VPN configuration to Mikrotik IPSec conf.
Netgear router connects fine, here are the logs:
2011-02-22 : INFO:  Flushing SAs for peer "XXX.XXX.dest.ip" with spi 1422077629
2011-02-22 : INFO:  Sending Informational Exchange: delete payload[]
2011-02-22 : INFO:  accept a request to establish IKE-SA: XXX.XXX.dest.ip
2011-02-22 : INFO:  Configuration found for XXX.XXX.dest.ip.
2011-02-22 : INFO:  Initiating new phase 2 negotiation: XXX.XXX.source.ip[500]<=>XXX.XXX.dest.ip[0]
2011-02-22 : WARNING:  attribute has been modified.
2011-02-22 : INFO:  IPsec-SA established: ESP/Tunnel XXX.XXX.dest.ip->XXX.XXX.source.ip with spi=26990430(0x19bd75e)
2011-02-22 : INFO:  IPsec-SA established: ESP/Tunnel XXX.XXX.source.ip->XXX.XXX.dest.ip with spi=1422077659(0x54c32edb)
So it looks like this:
  1. Netgear uses ESP (and not AH). —> not sure about that - looks like ESP from Netgear log (above)
  2. It uses tunneling
IKE POLICY:
3. from configuration menu i can read that it uses SHA-1 for authentication and 3DES for encrypton
4. It uses Pre-shared key (“_some_random_key”)
5. Dh group = 2 (1024)
6. SA lifetime 28800
7. it uses Aggressive mode
8. it uses User-FQDN: user@domain.de
9. it direction: Both
  1. Local net: 192.168.88.0/24
  2. Remote net: 172.16.0.0/16
    12: Remote IP have a Fixed XXX.XXX.destin.IP
    13: Local public IP, fixed: XXX.XXX.source.IP
I have read all the conf data from NETGEAR. I am using RouterOS v5.rc10.
The reason for v5 is /ip ipsec peer - my-id-user-fqdn parameter.
I have transfered all data to Mikrotik but i am still unable to connect to server with Mikrotik router.
Question 1: Is SHA-1 (Netgear) = SHA on Mikrotik (note the “-1”)
Question 2: Log entry error: “malformed cookie received or the spi expired.” - ANY IDEAS???
Here are log entries from Mikrotik router WHILE trying to ping the remote local IP (Through IPSec Tunnel)
13:48:54 ipsec,debug,packet agreed on pre-shared key auth.
13:48:54 ipsec,debug,packet hashtype = SHA:SHA
13:48:54 ipsec,debug,packet authmethod = pre-shared key:pre-shared key
13:48:54 ipsec,debug,packet dh_group = 1024-bit MODP group:1024-bit MODP group
13:48:54 ipsec,debug,packet an acceptable proposal found.
13:48:54 ipsec,debug,packet hmac(modp1024)
13:48:54 ipsec,debug,packet compute DH's shared.
13:48:54 ipsec,debug,packet the psk found.
13:48:54 ipsec,debug,packet hmac(hmac_sha1)
13:48:54 ipsec,debug,packet SKEYID computed:
13:48:54 ipsec,debug,packet SKEYID_d computed:
13:48:54 ipsec,debug,packet encryption(3des)
13:48:54 ipsec,debug,packet hash(sha1)
13:48:54 ipsec,debug,packet len(SKEYID_e) < len(Ka) (20 < 24), generating long key (Ka = K1 | K2 | ...)
13:48:54 ipsec,debug,packet compute intermediate encryption key K1
13:48:54 ipsec,debug,packet compute intermediate encryption key K2
13:48:54 ipsec,debug,packet final encryption key computed:
13:48:54 ipsec,debug,packet IV computed:
13:48:54 ipsec,debug,packet b7fb7a7c 61dd2a4d
13:48:54 ipsec,debug,packet HASH received:
13:48:54 ipsec,debug,packet 931dc71c 9617ddf0 7d61e4f0 c0fcca62 ec44e13b
13:48:54 ipsec,debug HASH mismatched  <===================ERROR???
13:48:54 ipsec,debug,packet compute IV for phase2
13:48:54 ipsec,debug,packet phase1 last IV:
13:48:54 ipsec,debug,packet begin encryption.
13:48:54 ipsec,debug,packet pad length = 4
13:48:54 ipsec,debug,packet 0b000018 fb989a3c 0f857486 e5dd2d07 abdb295a 4433872f 0000000c 00000001
13:48:54 ipsec,debug,packet 01000017 39ef5c03
13:48:54 ipsec,debug,packet with key:
13:48:54 ipsec,debug,packet ca99acd9 06c61209 0d781c6b 86441f45 35da3153 fd857775
13:48:54 ipsec,debug,packet encrypted payload by IV:
13:48:54 ipsec,debug,packet 2a57c310 cff42242
13:48:54 ipsec,debug,packet save IV for next:
13:48:54 ipsec,debug,packet 628aac96 5e4f94b6
13:48:54 ipsec,debug,packet encrypted.
ipsec,debug phase1 negotiation failed due to time up.
"malformed cookie received or the spi expired."  repeats every few seconds
  1. Yes, SHA is MikroTik is SHA-1, so thats not the problem.
  2. I have no experience with aggressiv mode and the use of FQDN, so I can’t advise you on that, but ‘debug HASH mismatched’ sounds like some of shared information, between the two routers, like PSK, IP and/or FQDN doesn’t add up.
Would that happen because one of two possible reasons:?
  1. Mismatched password?
  2. Old Netgear router is still connected and new router cannot connect until the old one is disconnected?
Yes to both, especially the second. But both should be easy tested. Try use a wrong PSK and see if the messages change.
