I use IPSEC VPN to link remote office with head one.
I noticed periodic ISAKMP-SA reestablishing (approximately 8 minutes):
16:03:01 ipsec begin Identity Protection mode.
16:03:02 ipsec ISAKMP-SA established 192.168.1.1[500]-192.168.1.101[500] spi:eaa599886d365e8a:2eb058ac8ccb1124
16:03:03 ipsec respond new phase 2 negotiation: 192.168.1.1[500]<=>192.168.1.101[500]
16:03:04 ipsec IPsec-SA established: ESP/Tunnel 192.168.1.101[0]->192.168.1.1[0] spi=128147769(0x7a36139)
16:03:04 ipsec IPsec-SA established: ESP/Tunnel 192.168.1.1[0]->192.168.1.101[0] spi=3694340472(0xdc332978)
16:10:39 ipsec ISAKMP-SA expired 192.168.1.1[500]-192.168.1.101[500] spi:eaa599886d365e8a:2eb058ac8ccb1124
16:10:40 ipsec ISAKMP-SA deleted 192.168.1.1[500]-192.168.1.101[500] spi:eaa599886d365e8a:2eb058ac8ccb1124
16:10:40 ipsec respond new phase 1 negotiation: 192.168.1.1[500]<=>192.168.1.101[500]
16:10:40 ipsec begin Identity Protection mode.
After several work hours several dozen installed SAs (in mature state) accumulates.
My configuration:
Main office: RB450G v3.26 Outer IP=192.168.1.1, serve 192.168.0.0/16 network
Remote office: Zyxel Prestige P334 as router IP=192.168.1.101, 2 computers (192.168.14.2, 192.168.14.3)
/ip ipsec policy print
Flags: X - disabled, D - dynamic, I - inactive
4 src-address=192.168.0.0/16:any dst-address=192.168.14.2/32:any protocol=all action=encrypt level=require
ipsec-protocols=esp tunnel=yes sa-src-address=192.168.1.1 sa-dst-address=192.168.1.101 proposal=default
priority=0
5 src-address=192.168.0.0/16:any dst-address=192.168.14.3/32:any protocol=all action=encrypt level=require
priority=0
/ip ipsec peer print
2 address=192.168.1.101/32:500 auth-method=pre-shared-key secret="top secret" generate-policy=no
exchange-mode=main send-initial-contact=yes nat-traversal=no proposal-check=claim hash-algorithm=sha1
enc-algorithm=3des dh-group=modp1024 lifetime=1d lifebytes=0 dpd-interval=disable-dpd dpd-maximum-failures=5
/ip ipsec proposal print
Flags: X - disabled
0 name="default" auth-algorithms=sha1 enc-algorithms=3des lifetime=1d pfs-group=modp1024
Finally after about 7-8 hours we get 2-3 hundred active SAs appears and 100% processor loading ![]()
What’s wrong?
