We have upgraded our Mikrotik (Roadworrier setup?) Form 6.44.5/6 to the latest Long term Version 6.47.10. This didn’t work even when the peer was set.
To find out where issue occurred I’ve downgraded to the first version that uses peer in /ip ipsec policy
I’ve added the peer correctly I think.
6.44.5
/ip ipsec policy
add dst-address=0.0.0.0/0 level=unique sa-dst-address=
sa-src-address=0.0.0.0 src-address=172.26.28.56/29 tunnel=yes
add dst-address=172.26.0.0/16 level=unique sa-dst-address=
sa-src-address=0.0.0.0 src-address=172.26.30.56/29 tunnel=yes
6.45.9
/ip ipsec policy
add action=none dst-address=172.26.28.0/22 src-address=172.26.28.0/22
add dst-address=0.0.0.0/0 level=unique peer=peer1 sa-dst-address=
yes
add dst-address=172.26.0.0/16 level=unique peer=peer1 sa-dst-address=
yes
To me the configuration looks fine.
When using Firmware version 6.44.5 the ipsec connection is setup correctly.
/ip ipsec profile
add dh-group=modp2048 enc-algorithm=aes-256 hash-algorithm=sha256 name=
profile_1
/ip ipsec peer
add address=/32 exchange-mode=ike2 name=peer1 profile=profile_1
/ip ipsec proposal
set [ find default=yes ] auth-algorithms=sha256 lifetime=1h pfs-group=none
/ip ipsec identity
add auth-method=rsa-signature certificate=
generate-policy=port-strict peer=peer1 remote-id=ignore
/ip ipsec policy
set 0 disabled=yes
strongswan log
Aug 2 16:52:04 strongswan ipsec[508]: 05[NET] received packet: from [4500] to [4500] (240 bytes)
Aug 2 16:52:04 strongswan ipsec[508]: 05[ENC] parsed CREATE_CHILD_SA response 45 [ No TSi TSr SA ]
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] selecting proposal:
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] proposal matches
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] received proposals: ESP:AES_CBC_256/HMAC_SHA2_256_128/NO_EXT_SEQ
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] configured proposals: ESP:AES_CBC_256/HMAC_SHA2_256_128/NO_EXT_SEQ
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] selected proposal: ESP:AES_CBC_256/HMAC_SHA2_256_128/NO_EXT_SEQ
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] selecting traffic selectors for us:
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] config: 0.0.0.0/0, received: 0.0.0.0/0 => match: 0.0.0.0/0
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] selecting traffic selectors for other:
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] config: 172.26.28.56/29, received: 172.26.28.56/29 => match: 172.26.28.56/29
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] config: 172.26.30.56/29, received: 172.26.28.56/29 => no match
Aug 2 16:52:04 strongswan ipsec[508]: 05[IKE] CHILD_SA mikrotik-hex{100420} established with SPIs caf85ecb_i 081e4c00_o and TS 0.0.0.0/0 === 172.26.28.56/29
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] proposing traffic selectors for us:
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] 0.0.0.0/0
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] proposing traffic selectors for other:
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] 172.26.28.56/29
Aug 2 16:52:04 strongswan ipsec[508]: 05[CFG] 172.26.30.56/29
Aug 2 16:52:04 strongswan ipsec[508]: 05[IKE] establishing CHILD_SA mikrotik-hex{100421} reqid 1432
Aug 2 16:52:04 strongswan ipsec[508]: 05[ENC] generating CREATE_CHILD_SA request 46 [ SA No TSi TSr ]
Aug 2 16:52:04 strongswan ipsec[508]: 05[NET] sending packet: from [4500] to [4500] (224 bytes)
6.45.9 doesn’t setup the connection correctly
/ip ipsec profile
profile_1
/ip ipsec peer
/ip ipsec proposal
/ip ipsec identity
add auth-method=digital-signature certificate=
/ip ipsec policy
set 0 disabled=yes
yes
yes
strongswan
Aug 2 13:20:26 strongswan ipsec[508]: 06[NET] received packet: from [4500] to [4500] (416 bytes)
Aug 2 13:20:26 strongswan ipsec[508]: 06[ENC] parsed CREATE_CHILD_SA request 63 [ No SA TSi TSr ]
Aug 2 13:20:26 strongswan ipsec[508]: 06[CFG] looking for a child config for 0.0.0.0/0 === 172.26.28.56/29
Aug 2 13:20:26 strongswan ipsec[508]: 06[CFG] proposing traffic selectors for us:
Aug 2 13:20:26 strongswan ipsec[508]: 06[CFG] 0.0.0.0/0
Aug 2 13:20:26 strongswan ipsec[508]: 06[CFG] proposing traffic selectors for other:
Aug 2 13:20:26 strongswan ipsec[508]: 06[CFG] /32
Aug 2 13:20:26 strongswan ipsec[508]: 06[IKE] traffic selectors 0.0.0.0/0 === 172.26.28.56/29 unacceptable
Aug 2 13:20:26 strongswan ipsec[508]: 06[IKE] failed to establish CHILD_SA, keeping IKE_SA
Aug 2 13:20:26 strongswan ipsec[508]: 06[ENC] generating CREATE_CHILD_SA response 63 [ N(TS_UNACCEPT) ]
Aug 2 13:20:26 strongswan ipsec[508]: 06[NET] sending packet: from [4500] to [4500] (80 bytes)
Is this a bug or is it a “misconfiguration”?
