I’m trying to set-up a VPN based on IpSec/L2TP. Everything works and I can use the VPN connection when connected. I see the L2TP tunnel listen under PPP ->Interfaces. But after one minute or so the L2TP tunnel drops. The IPSEC connection just stays connected. It looks like the L2TP does not get a reply on a HELO message and discconects then. See below the L2TP log where it ends. Does anyone have a clou? Tried already several things like from this topic: http://forum.mikrotik.com/t/ipsec-l2tp-vpn-on-mikrotik-behind-nat-but-with-fqdn/65755/1
Nov/15/2019 22:49:50 l2tp,debug,packet L2TPDBG===>: (M) Message-Type=HELLO
Nov/15/2019 22:49:52 l2tp,ppp,debug,packet L2TPDBG===>: <X.X.X.X>: sent LCP EchoReq id=0x7
Nov/15/2019 22:49:52 l2tp,ppp,debug,packet L2TPDBG===>: <magic 0xc25639d>
Nov/15/2019 22:49:52 l2tp,ppp,debug,packet L2TPDBG===>: <X.X.X.X>: rcvd LCP EchoRep id=0x7
Nov/15/2019 22:49:52 l2tp,ppp,debug,packet L2TPDBG===>: <magic 0x10400d01>
Nov/15/2019 22:49:54 l2tp,debug,packet L2TPDBG===>: sent control message to X.X.X.X:44758 from Y.Y.Y.Y:1701
Nov/15/2019 22:49:54 l2tp,debug,packet L2TPDBG===>: tunnel-id=37551, session-id=0, ns=2, nr=4
Nov/15/2019 22:49:54 l2tp,debug,packet L2TPDBG===>: (M) Message-Type=HELLO
Nov/15/2019 22:50:02 l2tp,debug,packet L2TPDBG===>: sent control message to X.X.X.X:44758 from Y.Y.Y.Y:1701
Nov/15/2019 22:50:02 l2tp,debug,packet L2TPDBG===>: tunnel-id=37551, session-id=0, ns=2, nr=4
Nov/15/2019 22:50:02 l2tp,debug,packet L2TPDBG===>: (M) Message-Type=HELLO
Nov/15/2019 22:50:10 l2tp,debug L2TPDBG===>: tunnel 12 received no replies, disconnecting
Nov/15/2019 22:50:10 l2tp,debug L2TPDBG===>: tunnel 12 entering state: dead
Nov/15/2019 22:50:10 l2tp,debug L2TPDBG===>: session 1 entering state: dead
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: LCP lowerdown
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: LCP closed
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: CCP lowerdown
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: BCP lowerdown
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: BCP down event in starting state
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: IPCP lowerdown
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: IPCP closed
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: IPV6CP lowerdown
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: IPV6CP down event in starting state
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: MPLSCP lowerdown
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: CCP close
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: BCP close
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: IPV6CP close
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: MPLSCP close
Nov/15/2019 22:50:10 l2tp,ppp,info L2TPDBG===>: : terminating… - hungup
Nov/15/2019 22:50:10 l2tp,ppp,debug L2TPDBG===>: <X.X.X.X>: LCP down event in starting state
Nov/15/2019 22:50:10 l2tp,ppp,info,account L2TPDBG===>: User1 logged out, 84 12694 16678 89 82
Nov/15/2019 22:50:10 l2tp,ppp,info L2TPDBG===>: : disconnected
