I need your help because I do not know where is the problem with the VPN I’m trying to configure.
I can see the client under IP/ IPSEC/Remote peers but when I check logs it shows error on phase 2 and I cannot establish vpn connection
Below is the current configuration topology
192.168.100.0/24 Lan ← Mikrotik → NAT 192.168.200.0/24 ← Router 1–> NAT Dynamic Public IP
Below Ports are forwarded on both NATs
UDP 500 → 500
ESP
AH
UDP Any → 1701
UDP Any → 4500
Does anyone knows what would be proper configuration for Windows 8 Clients ?
Check logs on MikroTik and Windows computer, I assume logs (debug logs on MikroTik) will give you more information.
On MikroTik RouterOS /ip ipsec policy and proposal are responsible for Phase 2 settings.
As well make sure that NAT is not disturbing your IPSec connection.
On Windows
Error 789 The L2TP connection attempt failed because security layer encountered processing error during initial negotiation with the remote computer
When I checked Log on Mikrotik this is what I see:
ipsec,debug,packet pair 2:
13:36:53 ipsec,debug,packet 0x47e2c0: next=(nil) tnext=(nil)
13:36:53 ipsec,debug,packet proposal #2: 1 transform
13:36:53 ipsec,debug,packet pair 3:
13:36:53 ipsec,debug,packet 0x47ef08: next=(nil) tnext=(nil)
13:36:53 ipsec,debug,packet proposal #3: 1 transform
13:36:53 ipsec,debug,packet get a source address of SP index from phase1 address because peer is behind NAT and we have to generate p
olicy.
13:36:53 ipsec,debug no policy template matching!
13:36:53 ipsec,error failed to pre-process ph2 packet. [/color][/b]
13:36:53 ipsec,debug,packet compute IV for phase2
13:36:53 ipsec,debug,packet phase1 last IV:
13:36:53 ipsec,debug,packet 749b01b0 5069caa1 cc655bb0
The outgoing traffic for this ports is enabled
I managed to fix this problem by changing Ipsec proposals pfs group to 1024
But now I have another on windows 8 client I receive error 809
any idea ?
olicy.
Check your NAT, and make sure it does not disturb IPSec communications.
Confirm that correct policy exists on your MikroTik router, as error shows that there is no such policy as required.
