Ipsec Mikrotik -> Juniper SRX
Please can i get some advice on this forum. I’m trying to setup a route based vpn from a mikrotik that sits behind a dynamic adsl line to a juniper srx that has a static ip address, from all the posts that i have read it seems the mikrotik only supports policy based ipsec vpns and not route based vpns?
Has anyone here done a route based vpn from a mikrotik to a juniper srx?
So the scenario is as follows:
192.168.0.0/24 → 10.0.0.0/24, 192.168.100.0/24, 10.255.255.0/24
10.0.0.0/24, 192.168.100.0/24, 10.255.255.0/24 ← 192.168.0.0/24
i want to be able to route those ranges aswell as new ones over the tunnel.
The 192.168.0.0/24 range has a dynamic dsl public addres that changes every so often
the other ranges are behind a juniper srx that has a static public ip address
RouterOS does not currently support IPSEC VTI/STI route based VPN’s.
You can however run GRE over IPSEC to a SRX or SSG and this works well.
i wonder if there will be plans to support this in future maybe?
