IPSEC MikroTik <-> pfSense 2.4
Hello!
I am a newbie to IPSEC and have limited knowledge of networking.
I am trying to set up a IPSEC and as far as that goes it is working, i get established on both ends, but no traffic passes thru.
I have tried to follow countless guides, but no luck.
So what am i doing wrong?
(Is there no need to set up a route on either device?)
On the pfSense i have set a firewall rule on ipsec interface to any-any.
My conf regarding IPSEC on my MikroTik is:
# apr/26/2018 10:19:17 by RouterOS 6.42.1
# software id = EIFW-UCH9
# model = RouterBOARD 3011UiAS
# serial number = xxxxxxxxxx
/ip ipsec proposal
set [ find default=yes ] disabled=yes enc-algorithms=aes-256-cbc lifetime=1h pfs-group=none
add auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=1h name=sha256-aes256cbc pfs-group=modp2048
/ip ipsec peer
add address=1.1.1.1/32 dh-group=modp2048 enc-algorithm=aes-256 exchange-mode=ike2 hash-algorithm=sha256 lifetime=8h notrack-chain=prerouting secret=secret
/ip ipsec policy
set 0 disabled=yes
add dst-address=10.10.2.0/24 proposal=sha256-aes256cbc sa-dst-address=1.1.1.1 sa-src-address=2.2.2.2 src-address=10.10.1.0/24 tunnel=yes
/ip firewall raw
add action=notrack chain=prerouting dst-address=10.10.2.0/24 src-address=10.10.1.0/24
add action=notrack chain=prerouting dst-address=10.10.1.0/24 src-address=10.10.2.0/24
add action=accept chain=input dst-port=4500 protocol=udp src-address=1.1.1.1
add action=accept chain=input protocol=ipsec-esp src-address=1.1.1.1
add action=accept chain=srcnat dst-address=10.10.2.0/24 src-address=10.10.1.0/24
Pure IPsec works using “policies”. A policy matches the source address and destination address (at least, sometimes also protocol and port if the protocol supports ports) of already routed packets, and if it finds a match, it “steals” the packet and sends it using the SA (security association) associated to the policy. So you do not need a route to choose a SA or IPsec peer for the packets, but you need some route for them so that they could be routed at all, because only in such case they can be matched and stolen by an IPsec policy.
