I am trying to setup an GRE over IPsec tunnel between a Mikrotik router (RB750Gr3; Running RouterOS 6.46.4) and a Raspberry Pi running IPsec-Tools and Racoon (The Pi is still running Raspbian Stretch).
While setting up a GRE tunnel is fairly easy (and so is IPsec when you get the hang of it), the combination of the two is giving me problems sofar. I cannot even get ICMP to flow through the tunnel, let alone GRE.
1.1.1.1 = WAN address Mikrotik.
2.2.2.2 = WAN address NAT router. The Raspberry Pi behind the NAT router has internal IP-address 192.168.2.2.
10.0.0.1/30 = GRE endpoint Mikrotik router
10.0.0.2/30 = GRE endpoint Raspberry
The Mikrotik router is configured as a responder, so the IPsec tunnel will only start when the Raspberry initiates traffic.
Configuration Mikrotik:
[admin@router] /ip ipsec peer print
Flags: X - disabled, D - dynamic, R - responder
1 R ;;; Raspberry
name="Raspberry" address=2.2.2.2/32 local-address=1.1.1.1 passive=yes profile=vpn-s2s
exchange-mode=main send-initial-contact=yes
[admin@router] /ip ipsec identity print
Flags: D - dynamic, X - disabled
0 ;;; Raspberry
peer=Raspberry auth-method=pre-shared-key secret="verysecretpassword" generate-policy=no
[admin@router] /ip ipsec profile print
Flags: * - default
4 name="vpn-s2s" hash-algorithm=sha256 enc-algorithm=aes-256 dh-group=modp2048,modp1024 lifetime=1d
proposal-check=obey nat-traversal=no dpd-interval=30s dpd-maximum-failures=3
[admin@router] /ip ipsec proposal print
Flags: X - disabled, * - default
1 name="vpn-s2s" auth-algorithms=sha256 enc-algorithms=aes-256-cbc lifetime=30m pfs-group=modp1024
[admin@router] /ip ipsec policy print detail
Flags: T - template, X - disabled, D - dynamic, I - invalid, A - active, * - default
1 A peer=Raspberry tunnel=yes src-address=10.0.0.1/32 src-port=any dst-address=10.0.0.2/32 dst-port=any
protocol=all action=encrypt level=require ipsec-protocols=esp sa-src-address=1.1.1.1
sa-dst-address=2.2.2.2 proposal=vpn-s2s ph2-count=1
Configuration Raspberry:
/etc/ipsec-tools.conf:
flush;
spdflush;
spdadd 10.0.0.2/32 10.0.0.1/32 any -P out ipsec
esp/tunnel/192.168.2.2-1.1.1.1/require;
spdadd 10.0.0.1/32 10.0.0.2/32 any -P in ipsec
esp/tunnel/1.1.1.1-192.168.2.2/require;
/etc/racoon/racoon.conf:
log notify;
path pre_shared_key "/etc/racoon/psk.txt";
path certificate "/etc/racoon/certs";
padding
maximum_length 20; # maximum padding length.
randomize off; # enable randomize length.
strict_check off; # enable strict check.
exclusive_tail off; # extract last one octet.
listen
adminsock disabled;
isakmp 192.168.2.2 [500];
isakmp_natt 192.168.2.2 [4500];
strict_address;
timer
counter 5;
interval 20 sec;
persend 1;
phase1 30 sec;
phase2 15 sec;
natt_keepalive 60 sec;
remote 1.1.1.1
exchange_mode main,base;
lifetime time 24 hour;
doi ipsec_doi;
situation identity_only;
send_cert off;
send_cr off;
verify_cert off;
initial_contact on;
proposal_check obey;
nat_traversal on;
dpd_delay 30;
dpd_maxfail 3;
proposal
encryption_algorithm aes256;
hash_algorithm sha256;
authentication_method pre_shared_key;
dh_group modp2048;
sainfo anonymous
pfs_group modp1024;
authentication_algorithm hmac_sha256;
compression_algorithm deflate;
/etc/racoon/psk.txt:
1.1.1.1 verysecretpassword
As GRE traffic did not make it through the tunnel, I decided to test using simple ICMP. I configured a vlan interface on the Mikrotik router (with an unused vlan number) and a dummy interface on the Raspberry and assigned each its 10.0.0.x/30 address.
As soon as I initiate an ICMP action (ping) from the Raspberry to the Mikrotik router, the IPsec connection comes online. Using ‘/tool sniffer’ I send the traffic to wireshark (which is running on my PC). I let wireshark decrypt the IPsec tunnel to see what traffic is running through the tunnel.
This is what I see:
622 15.561220 10.0.0.2 10.0.0.1 ICMP 225 Echo (ping) request id=0x0a0c, seq=1/256, ttl=64 (no response found!)
625 15.561646 10.0.0.2 10.0.0.1 ICMP 221 Echo (ping) request id=0x0a0c, seq=1/256, ttl=64 (no response found!)
The ICMP packet from the Raspberry to the Mikrotik router makes it through the IPsec tunnel, but does not get an answer.
NAT bypass for the 10.0.0.0/30 network on the Mikrotik router is active:
[adminfreek@PE1PQF] /ip firewall nat> print
0 ;;; NAT bypass
chain=srcnat action=accept src-address=10.0.0.0/30 log=no log-prefix="NATBYPASS"
However, packets never hit this rule. The question therefore is: Why do I not get a reply either way? (When the IPsec tunnel is established, pinging both ways does not work. I can see traffic going in the tunnel, but it never exits). It does not seem to be a firewall issue. Simple rules at the beginning of the input or forward chain allowing all traffic does not help.
Does anyone have an idea what is going wrong here?
