IPSec Mode Config issue
Hi guys )
Could you tell me please… I am using Mikrotik VPN to access external servers like 78.140.200.18 (for example) and the same for internal lan 192.168.150.0/24 (for example) and Windows OS working fine all routes pushes and no any troubles, but on Macbook not working if I using Split Include 78.140.200.18 only, all is ok, but together with 192.168.150.0/24 - not working… ( I think some issue with IKEv2 traffic and some other issues… maybe 192.168.150.0/24 set limit for 78.140.200.18, if I set 0.0.0.0/0 all working, but all Internet tfaffic going through MIkrotik VPN, but I need only Split Include routes. How can I do this? Other way, like L2TP VPN for Macbook where I can set Gateway default, because in Macbook IKEv2 by default all traffic want going through VPN and Macbook haven’t settings gateway for IKEv2… So many thx! p.s About Firewall Mikrotik, for test and 1st rule I set allow for 192.168.150.0/24 and 78.140.200.18 ofcourse. And my IPSec Policy is 0.0.0.0/0 to 172.16.0.0/24 - VPN internal IP’s.
For IKEv2 you should be able to ditch the split-include extension and configure proper traffic selectors.
IIRC on macOS IKEv2 client respects only the first network in the split. Didn’t test this in a while though, because see above.
