IPSEC Monitoring traffic
Good morning,
Is possible monitoring an IPSEC tunnel on MikroTik?
I need monitoring the forward traffic and make a graphic, for example using prtg or The Dude.
Does someone have an ideas for make this sensor type?
Thx
Replace your direct IPsec tunnel with a GRE/IPsec tunnel (or IPIP/IPsec) and you will have a separate virtual interface that you can monitor as usual.
WIth a direct IPsec tunnel that is not possible…
If you would have a “VPN” towards Azure this would not be an option. (I think, things evolve off course but…) Only IPSEC/IKE2 supported as far as I know.
I’m running such IPSEC connection into Azure (on my RB3011) but indeed it does not show as “an interface”.
