Hello I need your advice,
I havea working side 2 side VPN from my office to a custumer. My clients are connecting a VDI infrastrukture based on VMWare. The used protokoll is PCoIP(4172) UDP. Sometimes the local client ist loosing the mouse and keyboard and we have to close the VMWare Horizon client and start the work again. This is very frustrating due to the fact that we can't reconnect to the same VDI Windows client.
After some research I found a KB article that the VDI works wih a default MTU 1300. So I tried to change the MSS via magle rule for traffic going to the VDI but I did'nt see any traffic statistics with a changed MSS on the magle rule.
ip firewall mangle print stats
CHAIN ACTION BYTES PACKETS
0 ;;; internal-traffic packet mark
prerouting mark-packet 23 088 843 371 132 885 040
1 forward change-mss 0 0
Here are my settings.
NAME TYPE ACTUAL-MTU L2MTU MAX-L2MTU MAC-ADDRESS
0 R WAN ether 1500 1580 10222 E4:8D:8C:10:E9:04
4 R ether5 ether 1500 1580 10222 E4:8D:8C:10:E9:08
ADDRESS NETWORK INTERFACE
0 ;;; public_IP_03
x.x..x.253/29 x.x.x.248 WAN
4 ;;; PROD_AKTUELL
10.230.96.1/24 10.230.96.0 ether5
7 ;;; VPN-NAT-E
10.160.200.17/28 10.160.200.16 ether5
add action=src-nat chain=srcnat comment=E_NAT dst-address=10.208.217.0/24 log=yes log-prefix=ewe_nat src-address=10.230.96.0/24 to-addresses=10.160.200.17
add action=masquerade chain=srcnat dst-address=0.0.0.0/0 out-interface=WAN src-address=10.230.96.0/24
/ip firewall mangle based on a forum post,, are the endpoints correct or do I have to use the src-nat endpoint on my side?
chain=forward action=change-mss new-mss=1260 passthrough=yes tcp-flags=syn protocol=tcp src-address=10.230.96.0/24 dst-address=10.208.217.0/24 tcp-mss=!0-1260
log=yes log-prefix="mss_change"
ip ipsec peer print
;;; E
address=x.x.195.84/32 auth-method=pre-shared-key secret="secret" generate-policy=no policy-template-group=E exchange-mode=main
send-initial-contact=yes nat-traversal=no proposal-check=obey hash-algorithm=sha1 enc-algorithm=aes-256 dh-group=modp1024 lifetime=8h dpd-interval=30s
dpd-maximum-failures=5
ip ipsec policy print
A ;;; E
src-address=10.160.200.16/28 src-port=any dst-address=10.208.217.0/24 dst-port=any protocol=all action=encrypt level=unique ipsec-protocols=esp tunnel=yes
sa-src-address=x.x.8.253 sa-dst-address=x.x.195.84 proposal=E_proposal priority=0 ph2-count=1
So my question is, how can I be sure that the MTU has changed?
Whe I run the tools:
mturoute -4 10.208.217.245 I receive a Path MTU: 1406 bytes.
mtupath -4 10.208.217.245 MTU path scan to 10.208.217.245, ttl=64, limit=48
16 processing - best MSS 1378 (estimated MTU 1406) [pPPPPpPpPppPPPPp]
#1 MSS IN RANGE 1 <== 1377 ==> 1378
#2 MSS EXCEEDED 1379 <== 15005 ==> 16384
kind regards
Maedo
