IPsec Nordvpn no more connection
Since the last few Updates my NordVPN configuration doesn’t work anymore.
I don’t know if the Update is at fault or I changed anything I should not.
The problem is, that the router can’t connect to NordVPN. The router tries reconnecting every few seconds.
Here is a part from the log. I don’t know if thats help to find the error.
22:00:13 ipsec <- ike2 request, exchange: AUTH:4 5.180.62.54[4500] 13bee50222693665:69adc1ff8d728f96
22:00:13 ipsec,debug ===== sending 236 bytes from 87.181.207.42[4500] to 5.180.62.54[4500]
22:00:13 ipsec,debug 1 times of 240 bytes message will be sent to 5.180.62.54[4500]
22:00:15 ipsec,debug ===== received 76 bytes from 5.180.62.54[4500] to 87.181.207.42[4500]
22:00:15 ipsec -> ike2 reply, exchange: AUTH:4 5.180.62.54[4500] 13bee50222693665:69adc1ff8d728f96
22:00:15 ipsec payload seen: ENC (48 bytes)
22:00:15 ipsec processing payload: ENC
22:00:15 ipsec,debug => iv (size 0x10)
22:00:15 ipsec,debug 00c52864 9556711a 3a6bcb4f 9b35e707
22:00:15 ipsec,debug => plain payload (trimmed) (size 0x8)
22:00:15 ipsec,debug 00000008 04020004
22:00:15 ipsec,debug decrypted
22:00:15 ipsec payload seen: EAP (8 bytes)
22:00:15 ipsec processing payloads: NOTIFY (none found)
22:00:15 ipsec processing payload: EAP
22:00:15 ipsec,error EAP failed:
The Log is over 900 lines long. I don’t know if I can post the whole log, or if there any sensible data. Please advise me. If needed, I can post the whole thing.
I’m not really good in RouterOS, the most things I do with try and error :confused:
If you need any config to help me localise the problem, than please let me know.
By the way, I used this tutorial to set up the VPN.
https://wiki.mikrotik.com/wiki/IKEv2_EAP_between_NordVPN_and_RouterOS
In the beginning it works pretty well, but now I doesn’t know where I should search the problem.
I have deleted the whole ipsec config and tried to setup it new, but no success. Still the same problem.
I hope anybody can help me with it.
You should post the relevant part of your configuration. Something like this could help:
/ip ipsec export hide-sensitive
The NordVPN CA certificate is installed? System time is set correctly?
Thank you for your help.
Here is my ipsec config:
[stonie@MikroTik_Router] > /ip ipsec export hide-sensitive
# mar/02/2020 17:07:13 by RouterOS 6.46.4
# software id = JAQM-WPKB
# model = CCR1009-8G-1S-1S+
# serial number = 5A18043D07A0
/ip ipsec mode-config
add connection-mark=NordVPN name=NordVPN responder=no
/ip ipsec policy group
add name=NordVPN
/ip ipsec profile
add name=NordVPN
/ip ipsec peer
add address=de713.nordvpn.com exchange-mode=ike2 name=NordVPN profile=NordVPN
/ip ipsec proposal
set [ find default=yes ] enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc,3des pfs-group=none
add name=NordVPN pfs-group=none
/ip ipsec identity
add auth-method=eap certificate="" eap-methods=eap-mschapv2 generate-policy=port-strict mode-config=NordVPN peer=NordVPN policy-template-group=NordVPN username=xxxxx@xxxxmail.com
/ip ipsec policy
add dst-address=0.0.0.0/0 group=NordVPN proposal=NordVPN src-address=0.0.0.0/0 template=yes
Sytem time is one minute off to my PC, should be ok, or not?
Certificate is installed, like in the howto described:
[stonie@MikroTik_Router] > /certificate print where name~"root.der"
Flags: K - private-key, L - crl, C - smart-card-key, A - authority, I - issued, R - revoked, E - expired, T - trusted
 #         NAME                       COMMON-NAME                     SUBJECT-ALT-NAME                                                  FINGERPRINT
 0       T root.der_0                 NordVPN Root CA        8b5a495db498a6c2c8ca7af6ae4a...
The only think I found to be different is:
Mine:
add auth-algorithms=sha256,sha1 enc-algorithms=aes-256-cbc name=NordVPN pfs-group=none
I enforce sha256 for authorizations and encoding only aes-256-cbc. A bit slower but safer.
Thank you for your advice, but unfortunately still the same problem.
OmG how embarrassing, Only to test it I have entered the password new and now it works. :open_mouth:
Sorry guys that was really dumb.
I’m so sorry.
Nevertheless, thank you for your help.
No problem it happens to the best. :wink:
