IPSEC not connecting
I have a test lab setup and I’m using 2 Mikrotik routers to setup a test IPSEC tunnel. I have followed this guide : https://blog.pessoft.com/2016/05/29/mikrotik-ipsec-tunnel-with-ddns-and-nat/
I used static IP addresses instead of dynamic ( I have dynamic ones , but I would just like to see it up once before going into the script described in the article ).
I have also used Winbox instead of the terminal as I will have to make a Winbox howto in the end.
At this point I can see "connections " under Remote Peers , but under Installed SAs Keys I see this on the one side:
E
SPI : 0
Scr. Address : 192.168.1.10
Dst. Address : 129.205.36.224
Auth. Algorithm : none
Encr. Algorithm : none
On the other side the SAs Keys tab is blank.
What am I doing wrong here ? If you need more info to help me , please let me know and I will post it.
I have managed to fix this. It was my fault and the ADSL routers did not have DMZ setup correctly and one of them was also intercepting IPSEC trafic as it was able to handle IPSEC itself.
