Hello, I’ve set an ipsec tunnel between a Miktrotik an a checkpoint firewall.
I managed to stablish phase 2, but I see no traffic on the tunnel. I went trough some existing posts here on the forum, but none of the solutions actually worked for me.
My PH2 Total shows 1, and the state shows “established”
The downside of this application is that I can’t debug the chekcpoint router, so I have only the Mikrotik to play with.
Can someone help me if I need to create additional firewall rules or NAT rules?
Thanks!!
Her is my code:
dec/04/2023 10:37:57 by RouterOS 6.49.8
add comment=defconf name=bridge-LAN1
set [ find default-name=ether1 ] name=ether1-Wan
set [ find default-name=ether5 ] disabled=yes
set [ find default-name=ether6 ] disabled=yes
set [ find default-name=ether7 ] disabled=yes
set [ find default-name=ether8 ] disabled=yes
set [ find default-name=ether9 ] disabled=yes
set [ find default-name=ether10 ] disabled=yes
set [ find default-name=sfp1 ] disabled=yes
/interface pppoe-client
add add-default-route=yes disabled=no interface=ether1-Wan name=pppoe-out1
use-peer-dns=yes user=Wxxxxxx
add comment=defconf name=WAN
add comment=defconf name=LAN
set [ find default=yes ] supplicant-identity=xxxxxxx
/ip hotspot profile
/ip ipsec profile
add dh-group=modp768 enc-algorithm=3des hash-algorithm=md5 name=Castelvetro
/ip ipsec peer
add address=88.xx.xx.xxx/32 name=Castelvetro profile=Castelvetro
/ip ipsec proposal
add auth-algorithms=md5 enc-algorithms=3des lifetime=1h name=PhCastelvetro
pfs-group=none
add name=dhcp_pool0 ranges=192.168.228.2-192.168.228.254
add address-pool=dhcp_pool0 disabled=no interface=bridge-LAN1 name=dhcp1
add bridge=bridge-LAN1 comment=defconf interface=ether2
add bridge=bridge-LAN1 comment=defconf interface=ether3
add bridge=bridge-LAN1 comment=defconf interface=ether4
add comment=defconf interface=bridge-LAN1 list=LAN
add comment=defconf interface=pppoe-out1 list=WAN
add address=10.248.0.1/29 interface=ether5 network=10.248.0.0
add address=192.168.228.1/24 interface=bridge-LAN1 network=192.168.228.0
/ip dhcp-client
add comment=defconf disabled=no interface=ether1-Wan
add address=192.168.228.0/24 gateway=192.168.228.1
/ip firewall address-list
add address=83.xxx.xxx.74 list=DatabaseIpList
add address=192.168.1.0/24 list=DatabaseIpList
add address=10.30.146.128/25 list=DatabaseIpList
add address=83.xxx.xxx.64/27 list=SnmpIpList
add address=77.xxx.xxx.231 disabled=yes list=SnmpIpList
add action=accept chain=input in-interface-list=WAN log=yes protocol=
ipsec-esp
add action=drop chain=input dst-port=161 protocol=udp src-address-list=
!SnmpIpList
add action=drop chain=input dst-port=50080,2222,18291 protocol=tcp
src-address-list=!DatabaseIpList
add action=drop chain=input dst-port=53 in-interface-list=WAN log-prefix=
DNS-WAN protocol=udp
add action=accept chain=srcnat dst-address=192.168.55.0/24 src-address=
192.168.228.0/24
add action=masquerade chain=srcnat comment=“defconf: masquerade”
ipsec-policy=out,none out-interface=pppoe-out1
/ip ipsec identity
add peer=Castelvetro
/ip ipsec policy
add dst-address=192.168.55.0/24 peer=Castelvetro proposal=PhCastelvetro
src-address=192.168.228.0/24 tunnel=yes
/snmp
set contact=database enabled=yes location=Ixxxxxx
/system clock
set time-zone-name=Europe/Rome
/system identity
set name=Ixxxxx
/system note
set note=Ixxxxxx
/system ntp client
set enabled=yes primary-ntp=193.204.114.105
/system scheduler
add disabled=yes interval=1s name=reboot-mt-on-demand on-event=
“/system scheduler disable reboot-mt-on-demand;\r
\n/system reboot;” policy=
ftp,reboot,read,write,policy,test,password,sniff,sensitive,romon
start-date=jan/01/1970 start-time=00:00:00
/tool mac-server
/tool mac-server mac-winbox
