tried to configure IPSec, only partial success.. Can anyone please help to locate what I missed and should be changed to get it work?
routerOS: 6.47.1
network configuration:
Internet ----- media gateway <192.168.0.0/24> ----- <192.168.0.7> RB4011 <192.168.5.0/24, 192.168.7.0/24, 192.168.10.0/24)
Firewall to the router is open from the 192.168.10.0/24 subnet
what was set up
- CA + self-signed certificates for the router, clients
- CA + clients’ own cert imported to the clients
- I’ve added a bridge interface and the IP range 10.1.2.0/24 (.1 is the router’s address for the VPN endpoint)
I’m testing with 3 clients
- win10 64bit (client-DellE7250)
- iOS 13.5.1 (rphone7-2)
- android 10 (rik-S10e-2)
[a@RB4011] > ip ipsec profile print
Flags: * - default
0 * name="default" hash-algorithm=sha1 enc-algorithm=aes-128,3des dh-group=modp2048,modp1024 lifetime=1d proposal-check=obey nat-traversal=yes
dpd-interval=2m dpd-maximum-failures=5
1 name="ike2-profile" hash-algorithm=sha256 enc-algorithm=aes-256 dh-group=ecp256,modp2048,modp1024 lifetime=1d proposal-check=obey nat-traversal=yes
[a@RB4011] > /ip ipsec proposal print
Flags: X - disabled, * - default
0 * name="default" auth-algorithms=sha1 enc-algorithms=aes-256-cbc,aes-192-cbc,aes-128-cbc lifetime=30m pfs-group=modp1024
1 name="ike2-proposal" auth-algorithms=sha256,sha1 enc-algorithms=aes-256-cbc lifetime=8h pfs-group=none
[a@RB4011] > ip pool print
# NAME RANGES
0 dhcp_pool_guest 192.168.5.100-192.168.5.254
1 dhcp_pool_smarthome 192.168.7.100-192.168.7.254
2 dhcp_pool_lan 192.168.10.100-192.168.10.254
3 ike2-ippool 10.1.2.100-10.1.2.254
[a@RB4011] > /ip ipsec mode-config print
Flags: * - default, R - responder
0 * name="request-only" responder=no use-responder-dns=exclusively
1 R name="ike2-conf" system-dns=yes address-pool=ike2-ippool address-prefix-length=32 split-dns=""
[a@RB4011] > ip ipsec policy group print
Flags: * - default
# NAME
0 * default
1 ike2-policies
[a@RB4011] > ip ipsec policy print
Flags: T - template, B - backup, X - disabled, D - dynamic, I - invalid, A - active, * - default
# PEER TUNNEL SRC-ADDRESS DST-ADDRESS PROTOCOL ACTION LEVEL PH2-COUNT
0 T * ::/0 ::/0 all
1 T 0.0.0.0/0 10.1.2.0/24 all
[a@RB4011] > ip ipsec identity print
Flags: D - dynamic, X - disabled
0 peer=ike2-listener auth-method=digital-signature mode-config=ike2-conf match-by=certificate certificate=RB4011 remote-certificate=rik-S10e-2
generate-policy=port-strict policy-template-group=ike2-policies
1 peer=ike2-listener auth-method=digital-signature mode-config=ike2-conf match-by=certificate certificate=RB4011
remote-certificate=client-Dell7250 generate-policy=port-strict policy-template-group=ike2-policies
2 peer=ike2-listener auth-method=digital-signature mode-config=ike2-conf match-by=certificate certificate=RB4011 remote-certificate=rphone7-2
client-DellE7250
- cert is installed to the computer cert storage
- it’s set up to be used as ‘computer certificate’
- the windows’s client/machine name is the same as the name specified in the cert
- the client seemingly connects on the router’s end, but shows IKE authentication error in the win client and after the dpd timeout the connection is cleaned up.
[a@RB4011] > ip ipsec installed-sa print
Flags: H - hw-aead, A - AH, E - ESP
0 HE spi=0x5F08A7A src-address=192.168.10.112 dst-address=192.168.10.1 state=mature auth-algorithm=sha1 enc-algorithm=aes-cbc enc-key-size=256
auth-key="BBBBBBBB" enc-key="CCCCCC" add-lifetime=6h24m8s/8h10s
replay=128
1 HE spi=0xAD53128A src-address=192.168.10.1 dst-address=192.168.10.112 state=mature auth-algorithm=sha1 enc-algorithm=aes-cbc enc-key-size=256
auth-key="AAAAAAA" enc-key="ZZZZZZZZZZ" add-lifetime=6h24m8s/8h10s
replay=128
[a@RB4011] > ip ipsec active-peers print
Flags: R - responder, N - natt-peer
# ID STATE UPTIME PH2-TOTAL REMOTE-ADDRESS DYNAMIC-ADDRESS
0 R client-Dell7250 established 12s 1 192.168.10.112 10.1.2.101
what I can see, this is the only suspicious line in the log
17:22:10 ipsec ipsec::: processing payload: ID_R (not found)
The Android (built-in) client connects.
The iOS client connection setup aborts with an error
16:56:58 ipsec,error peer's ID does not match certificate
16:56:58 ipsec,error ipsec::: peer's ID does not match certificate
The client is set up as user auth=none, and use certificate is turned on, local Id is empty, remote ID is RB4011
I’ve read through several threads (among others: /viewtopic.php?f=2&t=155828 and /viewtopic.php?t=151259) but still no luck for the iOS and the win clients.
Bonus question: is it somehow possible to change the default entries (where there’s one) and then delete the current defaults? They are not needed..
