Having some issues getting our mikrotik to pass traffic through to the remote LAN.
LAN1 (10.4.4.0/24)- OpenSwan (10.4.4.103) - Firewall (Public) ------------- (Public) Mikrotik - (192.168.52.0/24) LAN2
I can ping devices on the LAN2 side from the LAN1 side but not from LAN2 to LAN1 except the vpn endpoint (10.4.4.103)
Here is the OpenSwan config
version 2.0 # conforms to second version of ipsec.conf specification
basic configuration
config setup
nat_traversal=yes
oe=off
protostack=netkey
uniqueids=yes
Add connections here
conn %default
type=tunnel
keyingtries=0
disablearrivalcheck=no
authby=secret
esp=3des-sha1
ike=3des-sha1-modp1024
keyexchange=ike
left=10.4.4.103
pfs=no
conn Mikrotik
leftsubnet=10.4.4.0/24
leftnexthop=%defaultroute
right=PUBLICIP
rightid=PUBLICIP
rightsubnet=192.168.52.0/24
rightnexthop=%defaultroute
auto=start
And the Mikrotik:
Flags: X - disabled, D - dynamic, I - inactive
0 src-address=192.168.52.0/24 src-port=any dst-address=10.4.4.0/24 dst-port=any protocol=all
action=encrypt level=unique ipsec-protocols=esp tunnel=yes sa-src-address=50.84.80.146
sa-dst-address=67.79.2.60 proposal=default priority=0
/ip ipsec proposal> print
Flags: X - disabled, * - default
0 * name=“default” auth-algorithms=sha1 enc-algorithms=3des lifetime=30m pfs-group=none
1 X name=“proposal1” auth-algorithms=md5 enc-algorithms=3des lifetime=30m pfs-group=modp1024
/ip firewall nat> print
0 chain=srcnat action=accept src-address=192.168.52.0/24 dst-address=10.4.4.0/24
Any insights? Again, LAN1 can ping devices on LAN2 but LAN2 can’t see devices on LAN1. Tunnel is established with no errors.
