IPSEC over EoIP - Dropping out
I have installed 6.30 on 3x routers to setup IPSEC over EoIP. The setup is easy, but after 24 hours, i seem to loose connection.
A reboot of one end can fix things, sometimes disabling the interface on the other end.
Am i alone in seeing this issue?
Interesting as we are doing some testing on that feature right now for a an article on EoIP performance over IPSEC @ stubarea51.net. I’ve been using two CCRs to do the testing.
What hardware are you seeing this issue on?
I think the main problem is the RB2011iL.
From my 3022iLs to a x86 machine, no dropouts. But from the 2011iL all 3x are offline until i Reboot.
I did try upgrading one end to 6.30.1 but couldnt get the tunnel up.
I think ill do all 4 and go from there.
We have lots of sites keen to start using this thats for sure!
