IPSEC over GRE tunnel with OSPF and multiple WAN issue
Hello I am new to the forum. I am trying to get multiple wan fail over working through the ipsec tunnel, I am trying to set it up so that if any 1 wan on either side goes down at the same time the tunnel stays up. I have created tunnel 1 and tunnel 2 and I can disable 1 wan connection on either side and the pings still go through to PC-1 and PC-2, however the issue comes when I try to create tunnel 3 and tunnel 4 EX 10.10.10.1/24 to 10.10.7.2 /24 I think the issue might be that they are on different subnets and my setup is on scaleway with GNS3 at the moment so I do not have real routable public ips on each router. All devices can ping out to the internet. Below is a screenshot of my setup in GNS3 at the moment. Any assistance or suggestions you can give would be helpful. Thanks in advance.
This might be off-topic but how did you manage to install chr on scaleway?
Any link you can provide me?
Kind Regards
